Page 54 of 137 FirstFirst ... 44450515253545556575864104 ... LastLast
Results 1,061 to 1,080 of 5300
    Jul 2010
    Quote Originally Posted by tuazon7 View Post
    yup, sabi na nga ba. pero how are you able to add Bosch horns, nag splice ka or full replace ng stock? Had replaced with an Accord horn yun sa Jazz namin dahil sa Honda-specific na horn connector...naiwas ako mag splice kasi...
    Fabricate po ng bracket sir, then use po yung extra m8 threaded hole from driver side at same hole sa pasenger side, ginamit ko po yung relay coil supply ng driver side horn tapos nag tap ako sa may fuse box ng supply sa bosch horn with harness at fuse. Gumamit po ako ng splicing clip para po sa relay. So far ok naman sa nagyun
    Sent from my SM-T719 using Tapatalk
    Jan 2011
    madami na dumating, puro S and SX daw pero ang haba kasi ng pila...hopefully makuha na nga nmin sa nxt week yun samin [emoji322]
    youre fine with 91... stick with the more recognizable gas stations. our guru has mentioned bigger companies have stricter policies.. cleaner storage? maybe? who knows?
    Sep 2017
    pero sir, assuming without admitting, hindi po ba sa fuel filter pa rin magaabot? thanks
    kasi tinatong ko yung mga matagal ng employee dun like 15 year na sya nag rerelease, yung nag briefing sakin, yung GSM yung engineers dun... tinanong ko sila separately, all are one in saying for them it doesnt matter. ewan ko lang. pero ako sa shell pa rin ako. napapag usapan lang po. hehe
    Quote Originally Posted by imjerome View Post
    ah yes! though some stations have caused headaches because of water and bad attendants putting the wrong fuel. youll be fine. your judgement is as good as ours
    Sep 2017
    copy that, sir! thanks
    pag bnew need mo certificate of cover before the casa allows you to drive out with the car. no casa will allow delivery without a COC
    Jan 2009
    Quote Originally Posted by moipogi View Post
    If you buy the car via cash payment, outside financing or bank PO, the dealership will allow you to pull the car out of the casa since the risk and rewards on the ownership of the car are no longer with them. If you buy it thru in-house financing, then that is a different story.
    Quote Originally Posted by studebaker View Post
    Di ko lang alam kung conservative yung mga dealers ko but all dealers I've encountered require COC before turnover to client. Company PO and own purchase. . .
    Jun 2010
    For bank PO, No casa will release a vehicle without Authority to deliver (ATD) from the bank. This is the last document casa needs before releasing. The bank will issue this upon receipt of all docs needed especially their copy of comprehensive ins.
    i buy my cars cash.
    i have no problems from the casa, if i drive 'em out that very same day.
    ako ang-i-insist na dapat in force na ang compre insurance ko before i drive it out. i make sure i have a copy of the insurance contract, indicating such, before i drive out.
    too many colleagues' tales, to take the chance.
    Usually mga hapon beep beep . . . lahat ng Jap cars na meron kami palagi palit horn, either PIAA or the bigger Denso/Bosch horns
    Jun 2008
    Di ba ma void ang warranty pag sa labas ipakabit ang horn?
    Quote Originally Posted by vtil View Post
    Have not encountered a properly installed horn to void an electrical warranty. As long as the horn in 12v and installed properly, there is very littel chance of a warranty being affected.
    But then again, of all the cars I've owned, all of them have been reliable on the electrical side. Nasisira madalas suspension and other high vibration parts.
    Haven't driven the CR-V much because LTO, but I've driven it enough to have a few observations:
    Not much difference between Eco mode and normal drive except in Eco, it seems to limit coasting and slows down when you let go of the gas.
    In normal drive it coasts when you let go of the gas so it feels like you could get more Km/L.
    The A/T does a good job of making the most out of available power. Although it does feel a bit jerky specially with light throttle inputs at low rpm.
    Suspension seems softer than the previous gen. Even with all tires at 40psi it still rides well. A little more floaty than the old one though.
    Malakas ba talaga yung wiper? Every time I wipe the windshield natatamaan yung kasalubong. Nababasa din yung driver side window and door sa lakas.
    Dec 2017
    Havent driven much with econ mode off if fuel efficiency is the same. But i can say that the times i have tried especially in winding hillside roads in subic, mas matagal magupshift if econ mode is off. So mas ok pag overtaking is necessary.
    Yung buga ng tubig for wiper is malakas on my unit.
    30 and 31 on nitrogen front and rear respectively. Masaya ako with suspension. Mas ok sa old xtrail, and new fortuner. Havent driven the previous gen.
    Jun 2012
    My center arm console squeaks. Do you have same experience? Im kinda disappointed. I put my elbow to rest and it makes flimsy sound.
    Sent from my Pixel using Tsikot Forums mobile app
    Oct 2017
    Quote Originally Posted by yecherchong View Post
    Sa kin naman my tumutunog sa third row seat. When you sway your behind from left to right my lumalagatok. Dedma na lang for the meantime rarely use naman ang third row and you won't hear it if you're just sitting still
    Nov 2017
    Wala naman ako na experience na ganun. Sa akin naman yung tumutunog sa ilalim driver seat area pag nakadaan ako ng potholes.
    buyers remorse. depression?
2017 Honda CR-V Turbo and 7seats
