Page 108 of 137 FirstFirst ... 85898104105106107108109110111112118 ... LastLast
Results 2,141 to 2,160 of 5300
    Aug 2009
    i found my busina in my non-honda, too loud.
    i tamed it by disconnecting one of the horns.
    Doc, if your route has a "jeepney/tricycle terminal", you'll want to return the other horn and add more sets
    Aug 2009
    Quote Originally Posted by yamahead View Post
    Thanks! I might go with that... Ideally, OEM... But due to scarcity, aftermarket brand will suffice. I prefer pot-pot over meep-meep. [emoji12]
    OEM route will set you around 6k na din almost with shipping. Since you've mentioned na impatient ka sa ganyan, baka na-upgrade mo na bago pa dumating yung OEM horns
    +1, pot-pot over meep-meep! Hehehe
    Quote Originally Posted by Sleepcare View Post
    Go with Mitsuba+horn adaptor nalang. Hanapin lang yung closest sound sa ibang higher models ng honda.
    Mitsuba yung sa yo bro? Which model? I just settled for Maruko BGD-2. Too many Bosch Europa users already. May nakasalubong akong PPV that had 4 pairs peeking behind his grill and bumper. That was the last straw hehe.
    *shadow
    Parang ang baba ng lumen output nung Philips 11362ULX2. 1,450 lumens lang? Yung 12362XVS2 na Xtremevision 1,350 - 1,650 lumens na rin. Any idea kung ilang lumens yung OEM bulb natin?
    I'm guessing limitation nung smallish passive cooling heatsink na maliit yung lumen output. Yung mga China na matataas yung lumens may mga cooling fan. Kaso malabo ang quality plus another point of failure pa yung fan.
    Jan 2011
    hoard here in Thailand, good for 3 years na siguro...
    Aug 2009
    Quote Originally Posted by tuazon7 View Post
    Sulit yung bayad sa freight ng box! Hehehe buti pa kayo may access to buy there
    *shadow
    I'm using PIAA superior bass but still on the fence whether to buy a Mitsuba horn. Probably the Proud Horn model lang.
    Actually sobra dami na Europa and ayaw ko na gumawa ng separate wiring kaya i resorted in buying the horn adaptor nalang.
    Addressed to shadow pero sisingit lang ako.. 800 lumens ata ang oem halogen na h11.
    Ayos din pala yang Superior Bass. Yung Mitsuba Proud sounds a little more "magalang" nga lang.
    Still haven't fitted my horn. I'll probably pick up a horn adapter doon na lang sa magkakabit.
    I don't mind you answering the query at all bro. Thanks for the assist. 800 lumens is so low.
    Di ko lang nadadala pa sa lugar na walang road lighting so I don't notice the weaksauce HLs as much.
    So looks like output-wise malakas na talaga yung Philips. Ang concern ko lang doon sa LED replacement is baka lumiit yung throw ng low beam. Maybe the halogen replacement bulb is better.
    Wala pa bang guinea pig na naka V?
    Aug 2009
    I'm actually on my 3rd pair of PIAA. Kaya lang gusto ko mag-Proud kasi titikim sana ako ng ibang ulam
    I think you can do it on your own basta lang malakas loob mo magtanggal ng clips sa upper grille area..
    Uber low kaya naghahanap na talaga ako ng replacement for the stock halogen bulbs. Actually yung throw din concern ko kaya ayaw ko din basta basta bumili. Si shadow kasi ayaw pa magpakabit! Hahaha
    Iba-iba sagot ng tinatanong kong mga stores eh sabi ng iba sabog pa rin kahit projector yun headlight sabi ng iba hinde daw ayaw naman nila I sample muna bago bayaran. [emoji39]
    Palitan na lang kaya natin buong headlight assembly to LED? Dami sa aliexpress. Plug and play lang daw
    Mamaya maghanap ako I'm currently in HK kung makakita ako nagbebenta ng Philips LED dito
    Parent gusto ko pumunta ng Bangkok. Sarap bumili doon ng mga OEM parts.
    Aside sa mga filters ano pa yun mga iba diyan nasa box?
    Jan 2011
    boss shadow air/fuel/cabin filters mostly for Jazz and CRV. Then meron lang naligaw na auto-boot switch and harness para sa DIY...
    Auto boot for crv?
    Jan 2011
    Auto boot for crv?
    yap, para sa CRV. Kumuha ako sa Autoease China, known ang quality nila sa auto-boot motors kasi. Yun switch na kasama okay naman kaya lang picky kasi ako kaya OEM habol hehe...
    Before using yung airfilter galing TH, don’t forget to cut the tab as the PH airbox has no provision for that tab and di mag fit ng maayos.
    Jan 2011
    Quote Originally Posted by gls2001 View Post
    Thanks bro!
    How much sa thailand yun LED heaslight assembly?
    Jan 2011
    Hindi pwede kumuha ng HL assembly sa TH, kabila ang bato ng ikaw kasi RH drive sila...
    Oo nga pala
    Wala rin Philips ultinon LED sa HK. Puro mga japan brands ang binebenta nila.
    Pwede kaya sa atin ito?
    Specifications of the X-tremeUltinon LED Headlight bulb 11362XUX2 | Philips
    Pwede ko pa ship sa pinsan ko. Ang mahal lang, ~Php7K before shipping.
    Feb 2005
    Not sure if same with the one I inquired yesterday, Maizone has Ultinon Essential(?) LED H11 bulb, selling it for Php4.5k
2017 Honda CR-V Turbo and 7seats
