Hi members, can you help me, im a newbie here. I just got problem that my 97 VTI has slow performance, too slow to accumulate speed. parang bitin....tune up lang ba katapat nya, please advise nmn...thanks and more power
Ganyan din Vti namin dati Hirap umarankada. Ang lakas pa sa gas..
Change Oil at tune up siguro katapat niyan.
Mikomaks - thanks for the reply
*silverworks. -- di nmn maingay ang makina, ang bagal tlga nya umarangkada at mabagal bumilis.....nabibitin ako sa performance nya...
tune up lang siguro to...![]()
[SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format & grammar. Use proper sentenses and paragraph construction. If your posted message is hard to read, less people will read it & respond.
Read the RULES.
Ignorance is NOT an excuse.
Repeated offenses will lead to banning.[/SIZE]
have the following done to your VTi:
1. change the oil and air filters
2. change the spark plugs
3. have the timing and valve adjustments checked and adjusted... VERY VERY IMPORTANT (HAVE THE CASA DO THIS ITS 990 PETOT
4. change the transmission oil... USE ONLY HONDA ATF-Z1 sa casa mo na rin pagawa ito
5. inflate your tires to 31 psi
6. remove unnecessary junk in your car
guaranteed, bibilis yan. as you drive your car and do research in the internet, you will understand why i want you to have these things done.
the regular "tune-up" sa gas station just won't do it. in fact, i think hindi naman tune up talaga ginagawa dito... simpleng palit lang ng spark plugs tune up na sa kanila. a true tune up involves setting the timing and adjusting the valve clearances... THIS IS VERY IMPORTANT FOR HONDA ENGINES
