Page 15 of 17 FirstFirst ... 511121314151617 LastLast
Results 281 to 300 of 328
    #281
    I was mulling on this too, bro....
    Hindi naman natuyo totally, just barely below the minimum, but I could not identify the color of the coolant, because it is below the radiator shroud.
    And again, I can't successfully remove the cover of the radiator....
    mukhang vacuum na bro, pero given the "age" mas ok yata iflush; this way may malaman kung OK pa condish ng cooling system.
    btw green pala kulay nya, akala ko blue din sa city
    re: rad cap, try mo hilahin yun hose papunta reservoir bro, kung may vacuum yan for sure released na yun hehehe
    if not baka yun sinabi ni bro bench nga wiggle it, just a little bit .. ^_^
    #282
    Its up to you kung palitan mo na coolant. Mine is due next year, being a 2010 car.
    I usually do this DIY. Being a condo dweller, dont have enough space & lighting to do it properly. I think its also a good time to replace the rad cap. What u guys think?
    #283
    i usually buy a spare bro pag medyo may edad na yun stuff na consumables. kaso madalas nagiging spare part/s sila LOL
    so meron ako rotor, brake pads, shoes etc. na pang vios hehehe
    #284
    Pwede ka na yata magtayo ng auto supply sa dami ng parts mo. Hehehe
    Be wary of fluids. May expiration yan.
    Speaking of Honda City nagka problema ka na din ba sa EPS mo?
    #285
    dati bro bago ako nakabili kay bro crazy boy, ngayon kasi sms nalang before OCI
    Aug 2005
    #286
    When the time came that our old 2009 City had to change its tires, we opted to use 195/55/15 using the stock rims. The same tire size was also used on the same generation Jazz.
    It drove much better - better grip. Or was it just the case that the stock Goodyear NCT5 was not a good tire in the first place?
    Sir,
    Hindi ba mas baba ng konti ung kotse? problem ko is mataas ang humps dito sa amin, sa 175 65 15 tire sumamayad sya eh cguro mas lalo sya sasayad kapag 195 55 15?
    Hindi ko tuloy mapalitan yung gulong ko ng 195
    Thanks po
    #287
    Quote Originally Posted by bhybhoy View Post
    Sir,
    Thanks po
    Mas mababa by 2% ang 195 55R15 vs. 175 65R15, so mas sayad.
    Bro.- i suggest you try the 195 60R15,- mas mataas by about 1% vs 175 65R15,- at maluwag naman ang wheel well,- so dapat kasya...
    Ipa-trial mount mo...
    #288
    Sir,
    Thanks po
    Nope, wala naman sayad. Wala rin sayad sa Jazz. We live in BF Homes and humps are almost everywhere. You just have to approach slowly those humps.
    Our 2014 Fiesta sits lower than our 2009 City/Jazz and uses lower-profile 195/50/16 tires. Rarely do I scrape the Fiesta's chin on humps unless I drive fast on them.
    Aug 2005
    #289
    Yan nga plano ko kaya lang ang hirap hanapin ang ganyang size, so i ended up with the old size 175
    Thanks
    Aug 2005
    #290
    Thanks sir,
    Mas mataas lang kase humps dito,kahit mabagal na ang takbo nasayad pa din kaya ang ginagawa ko is pa diagonal or palihis
    Pag nadaan naman ako sa ibang lugar na may humps hindi nman nasayad
    #291
    Sumasayad din ako kapag four adults ang sakay. Kapag dalawa kami or ako lang walang sayad.
    Madali naman “syumete” kapag may humps na. For me priceless yung response niya ngayon eversince nag 195/55/15 ako.
    Aug 2005
    #292
    Ok sir thanks sa info,
    Baka magpalit na rin ako.
    #293
    bro pano ginagawa pag sumasayad parin kahit slow down and 7 na?
    btw ano ba tumatama pag sumasayad ang auto?
    veteran nako sumayad, pero hanggang ngayon di ko alam alin ang tumatama hahaha
    #294
    Mahaba ang (front) overhang ng 2012 City bro. compared to other cars. So, iyong chin sa unahan ang sumasayad....
    Minsan nga nakalimutan kong City ang dala ko... Hayun, sumayad sa entrance ng Shopwise sa Sucat...
    #295
    Thanks
    Bro,- if you're from the south, sa Minerva mayroong 195 60R15..... Doon ako nagpalit ng gulong, but I chose the 55series....
    Pero, pansin ko lang mukhang hindi popular ang size na 195 60R15.
    Mas popular ang 195 55R15....
    Kasi, naghanap ako ng reserba (used tyres) at ito ngang 195 55R15 ang readily available...
    #296
    crawl under and make a look-see, after the sayad. but lifting the car is easier on your body.
    they should leave marks.
    many times, you can hear the sound and have a general idea of where it is.
    in my non-honda sedan, it's the tambucho at the rear.
    in my innova, it's the towing hooks underneath the engine/bumper.
    in the wigo... it has not yet sayaded, probably because it has very little overhang, and/or i have been lucky so far..
    btw, sayad is different from hitting the limits of the suspension when going over road imperfections with a heavy load..
    #297
    hmm masubukan nga yun pinagagawa ni dr.d
    medyo mataas yun harap nun altis bro, pero pababa ako sumasayad eh, pero im 99% sure di sya tambucho
    #298
    Parang exhaust pipe sumasayad kapag mataas na humps. FYI nasa ilalim ng front seats ang gas tank ng city/jazz.
    Nung una kinabahan ako akala ko yun ang sumasabit. Pagsilip ko hindi naman pala.
    Sep 2018
    #299
    Hi. Tanong ko lang ko kung pano lagyan ng beep sound yung honda city 2012 kapag ila-lock/unlock yung gamit key fob?
    Sep 2019
    #300
    Pareho lang po ba ang Specs ng 2010 at 2012 City?
2012 Honda City
