Last ko sya ask bagong palit daw pati flywheel & I believed him since me warranty naman to sa shop nya (me auto shop yung nabilihan ko)
Not sure lang kung Honda CVTF yung ginamit nya or generic. Will do change CVTF asap then will update this thread.
Cvt fluid changed with proper fluid?
Pa update po mga sir. Im expeeiencing same issue with my honda city 2006 idsi automatic. Lakas ng vibration when full stop lalo n pag nkbukas aircon at shift sa drive... Pero normal nmn ang idle... Pag nag shift sa reverse sa umpisa ung kumakalansing at makatal lalo. then eventually mwwala pag umatras na kotse.. When shift sa drive minsan may konting delay mga 1second bago umandar..dti kase pag bitaw ko sa brake mabilis response ng andar... Pero pag umaandar na maayos nmn at ok n ok din ang shifting.. Ang problem ay nag aarise lng malimit when full stop at aircon on at shift to drive o reverse. PLS HELP THANKS...
NOTE: napalitan n sparkplug, engine oil, cvtf, nalinis n throttle body, injector, normal ang bigay ng kuryente at ok lahat ignition coil at walang check engine. Yan napo nagawa sa kotse pero ndi padin po nwala ang problem....
If you've done most of the known possible causes, then my advice is to try and bring it to Honda service for their diagnosis. Even if there is a diagnostics fee, you can get what other possible causes they could find as the probable cause and decide how to proceed from there.
Nawala na ang shuddering nang transmission nang city 08 ko... Nagpalit lang ako nang cvtf sa honda ako mismo bumili and nag add nang Xado Revitalizant para sa cvt... November ko pinapaltan up to now di na bumalik ang shuddering
Sent from my INE-LX2 using Tapatalk
