Results 1 to 5 of 5
    1) Procedure: DIY replacement of burnt-out bulb of aircon button (beside the rear window heater button).
    2) Part No. or specs of replacement bulb.
    Will appreciate any info.
    Sent from my GT-I9505 using Tapatalk
    Jun 2009
    have you solve that replacement with DIY? I have the same concern too
    Quote Originally Posted by bleem002 View Post
    Not yet, bleem002. Still awaiting DIY info. Let's stay tuned...
    just in case may interesado pa. just replaced a cousins A/C button light. 2009 Jazz 1.5 GD but it will probably be the same o similar sa ge.
    all you need is a phillips screw, a small pry bar para lang mapindot yun tab ng button ma release sya.
    removing the a/c panel is just two screws the rest are just clips.
    bulbs are two (2) pieces of T3 neo wedge also called twist lock ata. that's it.
    after two years at maling nabiling bulb (dilaw na masyadong malaki is a t4.2) napalitan din yun bulb hehe.
    Thanks a ton. This rare info will go a long way.
    Sent from my SM-G930F using Tapatalk
A/C Button Light Replacement, Honda Jazz 1.5AT 2010
