Results 1 to 4 of 4
- Aug 2010
- 4
August 27th, 2010 11:39 AM #1Good Morning to ALL,
I have a 2002 Honda City 1.3L. The problem is during running condition when the speed is about 60km/hr, the temperature is normal. But when I accelerate it to 80~100km/hr, for some time the temperature suddenly increases. Then I will decelerate to 40km/hr, the temperature becomes normal again. I just notice that the reservoir, has boiling water inside which sometimes spills out the reservoir.
I have asked one technician, and said it was a problem on the gasket.
Is it true?
Please help me on this...
Thank you in advance...
- Dec 2006
- 234
August 27th, 2010 03:52 PM #2I had a similar problem on my 97 accord, turns out it was due to an under rated radiator cap.
Yours could be busted, if the gasket the technician was referring to is the gasket of the radiator cap, then you need to replace the radiator cap.
August 27th, 2010 05:14 PM #3
September 6th, 2010 09:33 AM #4
Boiling fluid means your radiator is getting defeated by the high pressure.
Your SX8 City Type Z requires a radiator cap pressure-rated for 1.1 bar or higher - this should be written on it.
Do NOT go lower. If you're using a cap with a lower pressure rating, such as the usual 0.9 bar, you have to replace it.
Start with this fix first as a radiator cap is pretty cheap and harmless compared to the other fixes. I'd agree with a flush and fill of radiator fluid as well - do NOT use plain water.
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
