Results 1 to 10 of 10
- Jan 2007
- 31
October 10th, 2010 02:01 PM #1mga sir, good afternoon. ask ko lang po if serviceable ang AC compressor. may umiingit kasi, at fisrt akala ko ung belt ng steering pump. compressor bearing pala. at my idea ba kayo how much ang price ng compressor for 2001 civic?thanks.
- Nov 2009
- 456
October 10th, 2010 07:34 PM #2Repairing a compressor is possible as long as the damage is not severe. The magnetic clutch and bearings can be replaced. But if the coil inside is busted, then its not repairable anymore. I suggest having the compressor checked and repaired as soon as possible before it gets worse.
October 10th, 2010 08:18 PM #3
October 19th, 2010 01:02 AM #4
Ok lang ba kung surplus nalang ang ipalit muna dun sa compressor 2001 model ng civic din.
Pa-inform nalang kung napaayos nyo na yun compressor bearing nyo. Saan at magkano inabot. tnx
October 19th, 2010 05:01 AM #5
October 19th, 2010 12:06 PM #6
noong na ondoy ang ES ko nagpalit ako ng compressor. Nasira din ang bearing. Nung una akala ko sa pulley lang, palit ako bearing ng pulley. Kaso maingay pa din and internal bearing na pala ang sira. Overhaul will cost around 4k including parts. Bumil nalang ako ng surplus 3.5k 2 weeks warranty. Just enough para maikabet at ma testing kung maayos pa.
So far ok naman yung surplus compressor mag iisang taon na wala problem sa a/c
October 20th, 2010 12:27 PM #7
- Oct 2010
- 6
October 20th, 2010 01:48 PM #8sir tanong lang po.. im planning po kasi on buying a second hand civic kso upon reading po d2 sa mga forum eh nalaman kong parang sakit ng ga civic ang over heating... yunn po bang civic na 2003 to 2005 eh my ganito pa rin pong issues?
salamat po sa mga magrereply...
- Jan 2007
- 31
October 28th, 2010 11:26 PM #9
