Results 1 to 2 of 2
- Aug 2010
- 6
August 31st, 2010 05:01 PM #1hello there iam currently a new owner of hilux 4x4 and new to this forum, i need your help on this video. any suggestion and recommendation on what to do to our hilux so this won't happen if ever (just in case) we need to do this manuever. pls thanks!! [ame="http://www.youtube.com/watch?v=aZF8N9NItHI"]YouTube- Toyota Hilux fails the Moose test[/ame]
- Mar 2007
- 25
February 2nd, 2011 08:45 PM #2for me i wouldnt worry much as hilux is designed for hauling loads and off roads and daily normal use. it is not designed for tight maneuvers and drifts.
but its about how bad you dont want that happen, you may forget lifting the body and macho tires and suspension, lower it down instead to lower down cg (center of gravity) and install sway bars.
we cannot just simply get all the best things in both worlds at the same time.
suggestion. you might try the local sarplas shops. the items will probably be painted in the color...
