we installed GPS Tracker / GSM Alarm to a honda civic the other day.
Today, Fortuner naman ( GPS tracker and 2din HU)
another Montero nacarnap dito sa amin sa taguig.
Sir Jedi, Pwede kaya it para sa mga trucks? Parang ok para mamonitor yung travel and at the same time anti hijack
sir di po sya conflict sa existing alarm, you can still use it. you can still use the builtin alarm ng gps tracker, nakaLOUD yung existing alarm mo, then yung sa gpstracker nakasilent or pwede rin sabay nakaloud... the gps tracker will still text you in case may alarm sa sasakyan
Sir yung cut off engine ba connected sa ECU? Wala po bang lalabas na check engine light?
My understanding about Tracker
Yung engine cutoff isolate yung power going to engine kaya mag shut off but not with your ECU. If you try to start the engine while engine cutoff may redondo yan but the engine will not run.
This is my experience, not sure with sir Jedi Tracker
Same lang ba sir jedi?
Tanong ko lang po Sir Jedi kung puwede ito kahit na may immobilizer ang sasakyan at hindi po ba siya maaapektuhan..Pasensiya na po sa tanong at noob pa..
sir JEDI, ito pala yung napagusapan natin nung sa UP carshow.
mas interesado ako dito kaysa sa PKE.
magkano pakabit/labor nito...?
di ba maaapektuhan sa existing alarm ko(autopage) dagdag ko lang ito as a GPS tracker.
nice boss JEDI.![]()
Master Jedi, interested ako sa GPS Tracker mo, if i order may free delivery po ba at saka nalang yung free installation that goes with it kasi wala pa ako sa pinas medyo matatagalan pa ang balik ko at tumatanggap po ba kayo ng online payment or bank transfer? sir pa PM nalang on how to make the payment, or maybe COD would be best i think, kaliwaan nalang po. Thanks
