Results 1 to 10 of 126
January 17th, 2011 06:50 PM #1
Tsikot will launch this new product soon.
Group Buy Discount will also be available
Detailed Product Description
GPS GPRS vehicle tracking Remote Engine-stop and Resume,track by google earth/real-time track by the monitor software in pc/WAP
GPS vehicle tracking system
Model: TsikotGPS103b
This tracker is a newly product based on the GSM / GPRS network and GPS satellite positioning system, which set multiple functions of security, positioning, monitoring surveillance, emergency alarms and tracking in its entirety.
Function Description
*Web based online tracking
*View map on cell phone, PDA, view target current location on map on the cell phone and PDA with the maps link in the message from tracker.
*If your target enters into underground parking lot or other GPS blind area, the tracker will inform you the last orientation.
*Remote Engine-stop and Resume.
*tracking function by timing and frequency
*Authorized number added and deleted function
*Support hidden alarm and monitor function
*Geo-fence: Set up a geo-fence for the unit to restrict its movements within a district. The unit will send the message to the authorized numbers when it breaches the district.
*Door Alarm
*ACC Alarm
*Movement alert: you can set up barriers when the vehicle is stopped. Once moved, it can give an alarm to the authorized number.
*Over speed alarm: you can make the inspected target run according to fixed speed. It alarms when speed is exceeded.
*Power supply disconnection alarm.
*Low batttery alarm function
*Check the vehicle status
*Set up "ARM" & "DISARM" State by remote control for DOOR ALARM, ACC ALARM, SENSOR ALARM.
Optional function:
*Quiver alarm
Applying directions:
Vehicle fleet/logistics/Vehicle rental
Technology parameter:
*Dimension: 83mm*54mm*26mm, 120g in weight
*GPS chip: SIRF3 chip
*channel: Parallel 20 channels
*sensitive: -159dBm
*Accuracy: 5m
*Time To First Fix Cold status 35s,Hot status 1s
*GSM Network frenquecy: 850/900/1800/1900Mhz
January 17th, 2011 07:09 PM #2
January 17th, 2011 07:14 PM #3
As long as I can afford it, I'm definitely interested. Please post additional details on how this will operate.
- Jun 2010
- 148
January 19th, 2011 01:42 PM #6
with rampant carjacking nowadays and recovery of stolen vehicles are almost impossible, this item is far more important and a must-have rather than spending on other mods.
pwede rin siguro to sa mga UB.
how much po sir jedi?
January 19th, 2011 10:05 PM #7
- 44
January 20th, 2011 06:28 PM #8Very nice item. Interested but depends on budget considerations, sana kakayanin ng budget.
January 20th, 2011 07:28 PM #9
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
