Results 1 to 10 of 34
- Jul 2011
- 4
July 21st, 2011 02:58 PM #1If you happen to see this car on the road, be careful when happen to chance upon it when lanes are merging. I happen to be beside this car yesterday along EDSA and I was already in the position to merge into his lane and was almost halfway into the lane. Then I noticed him squeeze in tight on my left side and when the lane moved, he made his move and rammed his right side mirror with mine. He didn't look at me when I tried to get his attention and he just moved past me and I saw him fix his side mirror shortly afterwards. I did notice though that his side mirror was already patched up pretty much which indicated that he did it intentionally to damage my side mirror. It was fortunate that mine was sturdier and was lined with plastic so no scratches and his ended up getting folded.
- Jul 2011
- 4
July 21st, 2011 05:50 PM #3
July 21st, 2011 08:41 PM #4
malaking kawalan sa kanya pag may nakasingit sa harap , makakatapat din yan na mas loko sa kanya.
July 21st, 2011 10:45 PM #5
BUT still the fact remains that HE IS IN THAT LANE and YOU are the one MERGING into that lane. he has the right of way, you don't. kahit nauuna pa kotse mo the vehicle in the lane will always have the right of way over another that is merging into that lane. should there be any damages you will be the one who will pay and not him.
July 22nd, 2011 09:28 AM #6
dapat ng ikaw ang magbigay nasa right of way siya. hindi porke gusto mong lumipat ng lane pwede na,tignan mo rin kung clear ba ito.
ito ang nakuha ko sa web regarding changing lane Do you drive a combination vehicle
Special Situations.
Special situations require more than regular mirror checks.
These are lane changes, turns, merges, and tight maneuvers.
Lane changes.
You need to check your mirror to make sure no one is alongside you or about to pass you.
Check your mirrors:
• Before you change lanes to make sure there is enough room.
• After you have signaled, to check that no one has moved out of your blind spot.
• Right after you start the lane change to double-check that your path is clear.
• After you complete the lane change.
Turns.
In turns, check your mirrors to make sure the rear of your vehicle will not hit anything.
Merges.
When merging, use your mirrors to make sure the gap in traffic is large enough for you to enter safely.
Tight maneuvers.
Any time you are driving in close quarters check your mirrors often. Make sure you have enough clearance.
SEEING
To be a safe driver you need to know what’s going on all around your vehicle. Not looking properly is a major cause of accidents.
Seeing Ahead
All drivers look ahead; but many don’t look far enough ahead. Importance of Looking Far Enough Ahead.
Because stopping or changing lanes can take a lot of distance, knowing what the traffic is doing on all sides of you is very important.
You need to look well ahead to make sure you have room to make these moves safely.
July 22nd, 2011 11:42 AM #7
agree ikaw dapat sir ang mag bibigay siya nasa tama according sa kwento mo
July 22nd, 2011 12:14 PM #8
eh sir ikaw nga sumingit eh.. dapat yung accord ang magalit sayo.. kung merging lane.. maghihintay ka lang dapat.. kung pagbigyan ka fine di singit ka.. pag hindi.. hintay ka pa din nung may magbibigay.. usually naman pag mga private cars nagbibigay naman yan.. mga taxi lang naman ang di marunong magbigay..
Tsikot Member Rank 4
- Jan 2003
- 2,979
July 22nd, 2011 01:57 PM #9bad driving habit na naging norm..... kawawa naman yun may-ari ng accord....
- Mar 2010
- 287
July 22nd, 2011 02:25 PM #10problema din kasi sa ibang driver minsan gusto lagi maka gulang.
subukan nyo yung daan from rockwell going to mandaluyong dami doon gusto sumingit na lang kaagad sa unahan kaya gagawin sa 2nd lane sila then sisingit nalang sila sa dulo.
while yung mga nasa left side na ang haba ng pinila nila eh di maka singit dahil sa kanila.
parang ganon ka TS dapat mag antay ka kung gusto mo hindi yung basta mo nalang ipapasok yung auto mo para lang maka gulang at maka una.
The Mitsubishi Xpander was PH’s top-selling MPV of 2023 | TopGear PH
2022 Mitsubishi Xpander
