Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Jun 2005
    a makati security guard turned enforcer flagged me down for alleged swerving.
    i came from the 3rd lane and changed lanes to the 2nd lane in ayala ave approaching rufino st. i was preparing to make a right turn to paseo de roxas that is why i tranferred lanes. the paseo de roxas intersection is about 300m away that is why i transferred lanes.
    i contested the apptehension and the enforcer made me sign a ticket that indicates disregard of traffic sign. when i indicated "under protest" the enforcer quickly changed the violation to swerving.
    im contesting the violation and have a scheduled hearing 2 weeks from now.
    Dec 2009
    Alam ko walang violation na swerving per se,, when you make a change in lane that is still swerving... By definition kase swerving is not being able to maintain a straight path.... We all know naman na we have to change lane every now and then, ang term ko diyan ay merging!
    Kase when we change our lane to another lane even if it takes a motorist 2 lanes to do that,, if he or she is careful then its like merging traffic, pag meh enough space in between you and another vehicle you can change lane after you have signaled...
    Grey area kasi yang swerving, kung sa tingin mo TS you did not cause any trafic obstruction nor did you put any car behind you at a disadvantage i think you have a basis for protest,,
    Jul 2006
    "Moving one lane to the left or right is not swerving, no matter where on the road you do it. And it is even less of a violation when you do it with a signal. Swerving is defined as shifting 2 or more lanes very quickly"
    got this in topgear ph
    2. Swerving is not a traffic violation. It is defined as a movement wherein vehicles shift from a lane to another. However, it can constitute the offense of reckless driving if it is done without precautions (e.g. swerving in an abrupt and careless manner, swerving without the use of signals).
    MMDA guide: 10 things every driver should know - Tip Sheet | TopGear.com.ph
    from mmda website:
    Swerving is not a traffic violation per se. It is defined as a movement wherein vehicles shift from a lane to another. However, it can constitute the offense of reckless driving if it is done without precautions (e.g. swerving in an abrupt and careless manner, swerving without the use of signals, swerving across solid lines).
    Swerving can also constitute the offense of Disregarding Traffic Signs if there are signs present that explicitly prohibit swerving in the area.
    http://www.mmda.gov.ph/faq.html#page-1
    Oct 2011
    may nabasa ako dati doon sa along ortigas-meralco ave. going to edsa. 1 lane na lang (right side) if you are going straight to edsa and I think 3 lanes ung turning left to meralco ave. madami na rin nahuling swerving doon. swerving to the right lane kahit moving one lane to the right lang.
    Jun 2005
    thanks for the input. this is actually my definition that i used against the enforcer. di raw ganun kasi pang mmda lang yun. wala naman siya ibang ibigay na definition.
    actually i was signaling my intentions to tranfsfer to the left lane. actually i drive there everyday to work. ngayon lang ako nadiskitahan
    Jun 2007
    ano daw kaya definition ng swerving sa Makati?
    Dec 2009
    Swerving kasi is a movement..it can never be a violation on itself... Pardon me, pero marami na engot at uneducated trafic enforcers on the road who don't even know how to drive nor define traffic rules when asked..!!!. What constitute for a violation is changing your lane without signaling or doing it recklessly that you are endagering other motorist... Kaya ang pwede violation sa ticket is reckless driving..
    Badtrip ako sa ganyan na mga enforcers na nag-dudunung dunungan! !
    Minsan hindi mo din masisisi kung makasagutan mo o ma encounter mo ang ganyan enforcer... Kaya nga minsan nasasapak o sampal sila eh...
    Protest mo yan sir,,
    Jun 2007
    abangan natin yung result ng protest
    Jun 2005
    madami irregularities dun sa huli ko.
    1. Swerving daw eh i just switched 1 lane
    2. 3 ang apprehending officers
    3. nung nagcontest ako ng swerving, ginawang disregarding traffic rules.
    4. after i indicated "under protest" sa ticket, sinulatan ng "swerving" ang ticket and disregarding traffic rules.
    galing diba? angas itong mga deputized security guard na mga ito eh. contest ko talaga ito
    Jul 2006
    gutom na siguro, kailangan dilehensya
    Jun 2007
    ^^ so hindi naka yellow (MAPSA) nanghuli sayo, naka dark blue (Makati Infra)?
    Jun 2007
    Jun 2007
    baka yung sinasabi nilang swerving eh violation #154 "disregarding lane markings"?
    Jun 2005
    Quote Originally Posted by dfopiso View Post
    yup. security guard na deputized na feeling yellow boy.
    Jun 2007
    ^^ dapat yung mga naka dark blue (Makati Infra) mag assist lang to ensure smooth traffic flow. MAPSA dapat manghuli
    Jun 2005
    sinulat talaga nya "swerving" after ko iprotest ang 154.
    technically, 154 and swerving ang nilagay nya
    Jul 2011
    Sa tingnin ko di susulpot mga yan sa hearing....lalo na pag lumabas ung circumstances ng pagkakahuli mo.
    Jun 2007
    malamang alam lang nung enforcer eh #154 pero hindi nya alam anong specific violation yon. tapos nag panggap alam, yun nilagay swerving
    Jun 2005
    i think alam nya 154 kasi yun una nya sinabi na disregarding traffic signs. nung sinulat ko lang na magcontest ako saka naman sinulat ang swerving. that was after ko magsulat ng under protest.
    btw, thanks dun sa inattach mo na picture. kinopya ko yung picture just in case. taga makati ka rin bro?
    Jan 2009
    Rule of thumb is, if it has a solid line, you cannot change lanes. You see these usually as you approach a traffic stop or intersection, on bridges, or winding multi-lane highways, etc.
    White solid lines separates lanes that are flowing in the same direction. Yellow solid lines (typically, but can also be white) separate lanes that are flowing in opposite directions.
    I'm thinking that the traffic enforcer caught you breaching the white solid line.
how do you define swerving?
