Page 1 of 3 123 LastLast
Results 1 to 20 of 60
    Jun 2006
    tanong ko lang po kung magkano mag drive ng manual.. sira po kasi matic ko kaya hihiramin ko kotse ng pinsan. pano basics ng manual? from start to finish po kung pwede kasi mahirap ng madisgrasya.
    Mar 2005
    ?? magkano??
    Jan 2004
    AFAIK, it takes time to learn how to drive an M/T vehicle. most likely, you'll find yourself stalling during the first few meters. magkaibang-magkaiba yung M/T at A/T. as for the 'magkano'? i don't get this, are you asking is there a manual how to drive a manual?
    three words...ride the clutch!
    FXT three words...ride the clutch!
    :bwahaha: Your pinsan will thank you for it when you return it.
    Jan 2004
    Quote Originally Posted by redorange
    that is, if you manage to get home without a wrecker towing your pinsan's car.
    Aug 2005
    baka magkano mag drive ng manual sa driving school.. mga 5-6k, sa A1.
    depress the clutch pedal during shifting at syempre brake pedal for braking.
    Jul 2005
    nagkamali lang siguro ng tanong yung tao, baka gusto nya malaman kung 'paano'?
    here's a tutorial...kinda long but i hope it helps. warning: once you learned manual, you may never go back to auto.
    http://www.10w40.com/individual/100186.asp
    Jun 2005
    It would have been much easier if it was the other way around (from manual to automatic tranny). The transition would be longer as you have to get used to the clutch control / gas pedal combination which cannot be learned easily. What you need is practice, practice and practice.
    Jun 2006
    mali yung words na type ko...dapat ay 'paano" dapat yung nakasulat dun.
    hehehehe di ganon kadali ang transition ng pagda-drive from A/T to MT (assuming na natuto kang magdrive sa A/t) than MT to A/T.....
    Yung misis ko tinuruan ko munang mag-drive sa MT at di sya masyadong nahirapan nung subukan nyang i-drive yung sasakyan ng hipag ko....it just takes her less than half an hour at medyo nakabisado na nya yung dirkarte....(di kasama ang overtaking ha...)
    pero yung hipag ko na sa A/T natuto...hanggang ngayon eh di maka-drive ng maayos ng MT....lalo na kapag me incline at nabitin sya... tapos nalilimutan pang mag-change gear.....parating nasa 1st or 2nd gear...nasanay kasi na isang ulit lang magka-kambyo.. tsaka madalas sumabit yung gear kapag nagkakambyo, nalilimutan kasing i-press ng todo yung clutch.....kaya nung kailangang ipaayos yung sasakyan nila, ayaw nyang manghiram sa amin kasi nakapagpaayos na sya ng clutch nung sasakyan namin eh....
    kaya ang maipapayo ko sa yo eh MAG TAXI ka na lang...herherherherher
    Jan 2004
    sir jonski, 'paano' would take time. but its worth it. tama si 5speed. actually, continous learning ang pagdadrive nang manual.
    Sep 2004
    True, true. M/T na minamaneho ko ever since, pero sometimes I still accidentally grind the gears, especially when shifting to reverse. Kaasar.
    Apr 2006
    huh? it says always to push the clutch before the brake. parang mali ah
    Jun 2006
    ano mangyayari pang from fourth gear eh aksidentng nailagay ko sa 1st? paranag kakatakot magdrive pero kelangan ko try. pano engine breaking nito?
    Aug 2005
    Quote Originally Posted by jonski
    mejo mahirap mangyari kasi di basta-basta papasok sa 1st gear yung kambyo if your running in 4th gear. para kasing may lock at kelangan mo talagang ipilit ipasok sa 1st gear.
    pag e-engine break mo, if your running in 4th gear, just go down 1 gear (3rd). although i'm not really sure if engine breaking is recommended.
    Noong nag-aaral pa akong mag-drive ng manual, praktis muna sa gears shifting na hindi umaandar then praktis ulit shifting gears na hindi tumatakbo but engine running... then hayun kahit medyo may kaba sige praktis na rin ako na tumatakbo. Konting lakas lang ng loob... medyo mahirap nga lang pag-incline na sya pero masasanay ka din sa mga kumbinasyon pag-nagtagal. Di ba kahit sino naman ay nagsimula sa wala talaga.
    Apr 2006
    hindi mo maikakambyo to basta basta to 1st gear kapag nasa fourth gear ka at mabilis takbo ng sasakyan... you have to decelerate first.
driving manual
