Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
    Mar 2003
    bwehehe, benta mo kse ng bente mil yang nissan mo, the veed. faggot car naman yan e
    Feb 2003
    any bad experience with Total? dun ako pakarga e
    Woulfe: Faggot nga, nasasamit, tumatama sa tonsils hehehehe...
    bardigones: Ako wala naman regardless of whether ProTec, Infinity or Unleaded.
    Jul 2005
    I read that E10 fuel (because of ethanol) will most likely absorb water and retain it (just like GH said) IF you have some water residue in your gas tank when you filled up. You don't encounter this with normal gasoline since it doesn't mix with the water content. Some also reported problems of the fuel filter clogging up because of the detergent properties of ethanol. These happen lang daw on the first few fill ups and after a while will just return to normal. (or so ive read... we don't have seaoil here in cebu )
    Just got news that my #2 fuel injector is shot... dunno if it's related though
    rusted?
    BTW, not confirmed but ethanol + water = gel-like resulting substance
    leaking injector...
    Dec 2002
    Quote Originally Posted by theveed
    leaking injector...
    May i ask what car and year model were you using?
    Sep 2004
    hmm.i've filled up in that same gas station a couple times, cheaper diesel on the farther most lane. but the station is not well kept, so i changed again. back to caltex.
    Sep 2005
    Its usually not the fuel brand but the station. Even here sa province, some Shell and Petron stations sell adulterated gasoline.
    The technique is to stick to a station that you found to be the most honest in the long run. Problem is its mostly a trial and error thing.
    Jul 2004
    saan ba meron sea oil near the Up diliman area other than the one near fairview?
    Mar 2003
    theveed, hwag ka na kse dun magmotel. alam ko suki ka sa orchids, pero try mo din yung mariposa sa marikina hehe
    Jan 2003
    am having 2nd thought tuloy sa seaoil.
    para kasi laha t ng seaoil stations e luma and not well maintained
    Hello tsikoteers,
    Last month I loaded my picanto sa E10 Seaoil edsa (between Abscbn and gma 7). Pag dating sa tomas morato round about tumirik ang auto ko. Normally sa seaoil sucat ako nagpapakarga ng e10 for my picant and bio exceed for my carnival.
    Anyway, we had the tank drain sa petron sa may tomas morato and found out that the e10 gas was dirty. We changed the fuel to extra unleaded and went back to seaoil edsa and showed their dirty fuel. they refunded me for my full tank at nag apologize. They ran out of e10 the week before and just loaded a tanker full of e10. so nagkaroon ng sludge yung tank nila because ofthe cleaning properties of e10. Hayun sumama sa pump.
    So far e10 is good to my picanto. nadale lang ako sa bad practices ng individual gas station.
    tnx
    rodski
    U13 Altima
    Rodski: Yep, station issue nga to... Nag E10 din ako before (Oct I think) and didn't have problems.
Bad Fuel Woes... SeaOil Shaw (Near Motels)
