Results 1 to 4 of 4
- May 2007
- 133
February 14th, 2009 04:37 PM #1mga papi ask ko lang po
kahapon kc e nagpalit ako ng radiator fan, oks naman
nga lang e naramdaman ko lumakas ung vibration ng makina kpag naka-ON ung fan, kumbaga.. sa loob ng car e ramdam na ramdam ung vibration
anyone who experienced the same?
my ride is corolla '95
thnx and Godbless!
February 15th, 2009 03:36 AM #2
You have a problem on your fan blade. Blade pitch is the angle of the fan blade in relation to the air stream, it is measured in inches from the fan mounting surface to the height of the leading edge of the blade. Increases in blade pitch are more effective in improving airflow at a given rpm but excessive pitch angles create some concern about vibration.
If you have noticed the tips of the fan blade they are curled back, this causes the air to move in a rearward direction instead of flying off the ends. You can compare the old blade of your car, the one you replaced and see the difference. This increases pressure behind the fan, rather than slung radial outward this wiil cause the vibration.
- May 2007
- 133
February 17th, 2009 02:08 PM #3thnx sir, kelangan ko po ba itong palitan? makakasira po ba ito sa engine? thnx
manual ba ang innova mo?
