The average replacement time in terms of kilometers is 80,000 kms. the timing belt is a key component sa kotse bro. Pag naputulan ka nito overhaul na. Mura lang naman.
The owner's manual for the Mitsubishi Adventure recommends replacing it between 60,000-80,000 kms., assuming OEM belts are used. I had mine replaced at 75,000.
Expect a shorter replacement interval if non-OEM belts are used, although there are claims that certain aftermarket belts are less prone to stretching compared to OEM ones, preserving the engine timing.
If 10 years na, I would recommend that you change your timing belt.... Lumulutong at nabubungi iyan due to the normal wear and tear of the unit/material.....
