Results 1 to 10 of 12
January 4th, 2006 05:38 PM #1
Guys,
I noticed there is a big diferrence in accelerator pedals between a 1999 camry and my nissan exalta STA....yung sa camry super lambot..yung sakin medyo maganit..is this normal? Depende ba sa make ng car?
please comment..
thanks,
city
January 4th, 2006 05:56 PM #3
thanks ghosthunter....is there a way to make mine smoother like the camry?
city
January 4th, 2006 06:27 PM #4
paminsan kasi perceived smoothness is dependent on how smooth the engine/tranny actually is.
Depende din sa pano ginawa ang throttle cable system...
January 5th, 2006 10:13 AM #5Originally Posted by theveed
thanks theveed!..it's strange the exalta throttle cable loops around on top of the engine....can this modified because the engine gets hot and probably the cable lube is drying up?
regards,
city
January 5th, 2006 12:40 PM #6
Nah, I doubt it coz most engines ganun ang setup. I honestly doubt that it has any direct relation with the cable itself... If mahina ang makina naturally mas mabigat ang throttle compared to a larger engined car. Lalo na kung automatic pre.
January 5th, 2006 05:50 PM #8
you can have the return spring (of the accelerator pedal) adjusted slightly for a softer feel.
January 5th, 2006 07:13 PM #9
may problem ung sa throttle pedal ng civic namin. maganit siya, pero pag ginalaw ko ung cable mismo don sa may engine bay. pag apak ko don sa pedal ayos na ulit. bat kaya ganon? tinatanggal ko lang ung cable sa pagkakalagay niya tapos loop ko na ulit. ayun ok na. pero pag tagal bumabalik din sa dating problema. pano kay un?
I've looked into it before but changed my mind. On paper, they run circles around lead-acid...
Lithium-ion Batteries?
