1. kuha ka ng softdrink can (mas effective yung coke na red, less yung diet). open it, drink the contents. you'll need the sugar for the task ahead.
2. cut off the softdrink can ends. that will leave you a tube.
3. cut diagonally 6 equal 2 inch deep slats on one end of the can. bend the ends inward, in the shape of a propeller blade. that will make 6 blades.
4. remove the rubber tube connecting the air filter housing to the throttle body. insert the home-made tornado near the throttle body. make sure it stays in place by putting a 3" hose clamp on the outside of the rubber tube to hold on the can.
5. install back rubber tube. there! may home made DIY tornado ka na! naka-save ka ng P3500.
note: for those with big throttle bodies, a del monte pineapple chunks can will be best. pag mas maliit naman, pwede yung 555 sardines.
