Results 1 to 19 of 19
    Dec 2003
    Is it worth it?
    Who sells them in the Philippines/ Manila, most of the people I talked to doesn't even know they exist.
    anu po yan?
    Dec 2003
    Sun Auto Hyperground System
    This system provides direct ground path from battery negative to body, chassis, and engine components to give extreme improvement on electrical circulation.
    In addition "Hyper Ground System" cables have 10 times less impedance than factory ground systems which
    provides immaculate
    conduction to prevent electrical power loss.The higher resistance of factory grounds, effect the ignition system and obstructs the primary potential.
    The "Hyper Ground System" uses thick gauge 99.99% pure copper, and connects directly from the cylinder head and other points under the hood to the battery, to provide an ultra low resistance connection.This will increase the primary potential of regular cars to ignition tuned vehicles.
    http://www.sunautomobile.com/
    yan ata un earthing ba un na naririnig ko dati sa clubmitsu...
    Nov 2003
    we've got some earthing kits in the shop. almost same specs as the SUN kits pero manufactured here. give the shop a call at 7237625.
    thanks!
    Dec 2003
    Actually there have been conflicting opinions on buying branded VS DIY ground systems.
    I wanna go with the branded side of things so I'd appreciate it if anyone knows where this brand sells otherwise I may be considering ordering from the net.
    Nov 2003
    actually the bad rap about the DIY grounds are due to crappy materials being used in the making of the grounds.
    check out what we have kasi you may fin it reasonable kaysa sa SUN na kit which retails for around $100 + shipping and handling pa.
    also, it is the optimal placement of the wires that brings about the best improvements and even wires like the SUN brand necessitate dyno sessions before the best location can be found on each car
    Dec 2003
    Actually $115 :freak:
    Nov 2003
    lalabas yan almost 8k or maybe more once you've had it shipped.
    magkano sanyo ser speedyfix...?
    anu mga gains nyan?
    Nov 2003
    odell you have PM
    Dec 2003
    Originally posted by speedyfix
    odell you have PM
    Oo nga send me info on your grounding KIT, and how much install sa inyo if I got a kit somewhere else.
    How about TODA CAMS meron din ba?
    Nov 2003
    you've got pm
    how much sa inyo speedyfix? paki quote na din for 5k pms. s3
    Jan 2003
    Quote Originally Posted by speedyfix
    thanks!
    meron pa ba kayong stock? and how much po?
    thnx
    Jun 2004
    speedyfix,
    pwede PM po ang price?
    thanks!
    I have mine bought sa HK at around HK$ 100 (~ 720 Pesos) but of different brand. I installed it and one thing na notice ko sa XTO A/T at tumaas yung milage ko. from previous 7+ km/liter to ~9 km/liter. I always check kasi my milage and never na hit ko yung 8 km/liter since day 1. I used the same gas station and gas pump number kaya alam ko yung milage ko.
    Aug 2004
    ako din po mr speedyfix.pa pm ng price thnk you!
