Results 1 to 10 of 19
April 24th, 2004 02:22 AM #1
Is it worth it?
Who sells them in the Philippines/ Manila, most of the people I talked to doesn't even know they exist.
April 24th, 2004 03:17 AM #3
Sun Auto Hyperground System
This system provides direct ground path from battery negative to body, chassis, and engine components to give extreme improvement on electrical circulation.
In addition "Hyper Ground System" cables have 10 times less impedance than factory ground systems which
provides immaculate
conduction to prevent electrical power loss.The higher resistance of factory grounds, effect the ignition system and obstructs the primary potential.
The "Hyper Ground System" uses thick gauge 99.99% pure copper, and connects directly from the cylinder head and other points under the hood to the battery, to provide an ultra low resistance connection.This will increase the primary potential of regular cars to ignition tuned vehicles.
http://www.sunautomobile.com/
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 27th, 2004 03:04 AM #5we've got some earthing kits in the shop. almost same specs as the SUN kits pero manufactured here. give the shop a call at 7237625.
thanks!
April 30th, 2004 03:58 AM #6
Actually there have been conflicting opinions on buying branded VS DIY ground systems.
I wanna go with the branded side of things so I'd appreciate it if anyone knows where this brand sells otherwise I may be considering ordering from the net.
- Nov 2003
- 3,848
May 1st, 2004 03:14 AM #7actually the bad rap about the DIY grounds are due to crappy materials being used in the making of the grounds.
check out what we have kasi you may fin it reasonable kaysa sa SUN na kit which retails for around $100 + shipping and handling pa.
also, it is the optimal placement of the wires that brings about the best improvements and even wires like the SUN brand necessitate dyno sessions before the best location can be found on each car
- Nov 2003
- 3,848
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
