Results 11 to 20 of 45
Tsikot Member Rank 4
- Jan 2003
- 1,403
March 27th, 2007 04:01 PM #11I guess you're right. Technically and legally (I think) it is a trike. Per LTO, "MC refers to motorcycles and mopeds, both with and without sidecar; motor vehicles with a seat or saddle for use of the rider and is designed to travel with not more than three wheels in contact with the ground. Four wheels may be in contact with the ground when two of the wheels are functional parts of the sidecar."
But that would imply I can't use it on major thoroughfares, including the NLEX/SLEX, wouldn't it?
As an aside, even though technically it is correct, lumping the XR3 together with tricycles seems rather bereft of any aesthetical rationale, don't you think so?
- Jan 2003
- 1,403
March 27th, 2007 04:15 PM #12That's exactly my problem. The rules are somewhat ambiguous, the implementing guidelines even worse, and actual implementation simply inconsistent if not non-existent. Thus it is difficult to ascertain which is legal and which is not.
The posts in this thread certainly do reflect the confusion, as some of them even reflect my own level of ignorance.
But personally, the fact that other vehicle owners get away with illegal or iffy stuff (wangwangs, tinted plates, etc.) has no bearing on my decision-making. I just want to abide by the law for the simple reason it will hopefully mean less hassle for me. But if in doing so, it renders the XR3 impractical for me, then I guess it is a no-go. Of course, as others have pointed out, safety is the other major consideration.
Anyway, since tatlong beses na akong nakakakita ng Smart Fortwo cars sa EDSA, baka nga pwede yan dito, although I'd guess there would be certain limitations.
- Jan 2003
- 1,403
March 27th, 2007 04:24 PM #13Hi redorange,
I think you must be referring to either the Tri-Magnum or the T-Rex, both of which are quite popular in the Bay Area. In fact, the San Leandro Car Show often features one if not both of them. Incidentally the Tri-Magnum is also designed by Riley.
And yes, they are classified as MCs, which brings about its own set of restrictions and requirements.
March 27th, 2007 04:58 PM #14
As long as the vehicle has working headlights, tail-lights and signal lights, it's road legal. Never mind if it has the structural integrity of wet spaghetti.
As long as it has more than 400ccs of engine, any two or three wheeled vehicle can get on the highways. They might require you to wear a helmet if they classify it as a motorcycle, though. I talked to the owner of a micro-jeep (basically, an open-topped imitation Wrangler built on a Suzuki SuperCarry wheelbase... about seven feet long and small as hell), and he said they required him to wear a helmet due to the vehicle's size or lack of belts... not sure which.
The limitations for EDSA are similar. Pedicabs and Tricycles aren't allowed, but scooters and motorbikes are.
March 27th, 2007 05:01 PM #15
stay conservative then para "iwas pusoy" ka, unless you know someone within the hierarchy, or use a prova plate...
just curious, how fast does that thing go bec the chassis looked like it underwent wind tunnel testing- makes it harder to classify for homologation purposes. why not change the chassis to somewhat familiar and less threatening (the thing might scare everyone in the highway you know) like those multi purpose cabs perhaps they might overlook the missing wheel?
- Jan 2003
- 1,403
March 27th, 2007 05:31 PM #16It is not a question of whether I have connections or not, because if the registration is illegal to begin with, I will be frequently stopped by the authorities, and rightfully so. That is what I would like to avoid.
- Jan 2003
- 1,403
March 27th, 2007 05:35 PM #17
March 27th, 2007 08:01 PM #18
March 27th, 2007 11:20 PM #19
The T-Rex is one but they also these.
http://www.zapworld.com/ZAPWorld.aspx?id=890
March 27th, 2007 11:29 PM #20
imo, any type of transport that is not running w/ 4 wheels would be considered a tri/bicycle/motorcycle
Latest mileage:
