anong klaseng sealant yung ginagamit sa plastic that cover the door panels? yung pagbaklas mo d ba may plastic sya normally. anong klaseng sealant pandikit dito?
and ano din yung ginagamit when you install headlamps or taillights. para water doesn't seep thru the space between the metal body and the lamps.
I thinks the black sealant sa door is a low grade silicon gasket na itim. and the headlamps and tail lights are the highend type na white or clear na silicon gasket.
