Results 11 to 20 of 50
December 23rd, 2009 05:53 AM #11
December 23rd, 2009 09:41 AM #12
What the article didn't address is that using fully-synthetic motor oils (of the correct viscosity) will allow you to prolong the oil change interval, usually twice as long as compared to using dino/mineral oil.
Also, I disagree about the tire pressure listed on the door jamb as being the maximum pressure allowed. The REAL max pressure that the tire can hold is stamped on the sidewall. For instance, the typical 205/55 16 tires used on the Civic 1.8S has max pressure of 50-51 PSI, as indicated on the tire sidewall. However, the tire pressure listed on the door jamb as recommended by Honda is 32 PSI.
December 23rd, 2009 11:09 AM #13
That actually a good read, most apply for people who don't really maintain their own cars but fun to read. If I may add, when I was in Phil. was changing my mom's cars battery, a mechanic asked me not to put the new battery on the ground I asked why he replayed it will get discharge? don't know if thats a Filipino thing. but I didn't listen actually put the battery longer on the ground just to prove a point.
Myth: If you put your car battery on the ground it will get discharge
Reality: a car battery external is made out of propylene plastic and it will not conduct electricity.
December 23rd, 2009 12:09 PM #14
Yep it does, but it's not quite necessary for road driving. Your cooling system and engine aren't quite thermally stressed enough in daily drives - it's perfectly okay if you don't do it.
At trackday events on the other hand, I've seen it's become somewhat of a standard practice to pop the hoods of cars after completing a series of hot laps and coming into the paddock. Everything is thermally stressed there - brakes, tires, drivetrain, cooling system and engine - so it becomes a good idea to do this and relieve the heat.
December 23rd, 2009 12:35 PM #15
December 28th, 2009 09:51 AM #16
dapat ba na kapag patay ang makina hindi dapat inaapakan ang accelerator pedal para hindi daw magoverflow ang gas, kasi daw pagnagkataon mahihirapan mag start ang makina..yan ang sabi ng tatay ko sakin...
myth or reality?
December 29th, 2009 10:09 AM #19
Daming issue ng SU7:grin:
Xiaomi E-Car
