Results 1 to 8 of 8
- May 2007
- 133
December 9th, 2008 01:14 PM #1hello po mga peeps..
ask ko lang kung ano kaya ang possible na problem.. napansin ko kc madalas ang lakas mabawasan ng tubig ko sa radiator, pero wala naman akong nakikitang tagas.. malimit e nagdadagdag ako ng tubig. Ano po kaya ang possible na problem? my ride is corolla 95
thanks in advance! Godbless!
December 9th, 2008 01:41 PM #2
diyos mio! kakagaling lang ako sa ganyang predicament this past weekend, radiator hell, i tell you. nasimot ang buong weekend ko kaka troubleshoot and paayus and pa-backjob na paayus ulet *sigh*
anyways, just some useful tips that might help you as well:
1. Check all hoses (kung sure ka na walang leaks) for holes or loose clamps
2. Check and test you auxillary fan na rin
3. Check radiator cap
4. Just for the sake of it, DOUBLE check for leaks (some kasi are really small, pero sisingaw yan under pressure hence it wouldn't produce any visible droplets.
5. shempre, have it checked by your trusted mechanic or radiator specialist.
- May 2007
- 133
December 10th, 2008 02:05 PM #4
Wala ka nkikita na tagas dahil wala ka coolant to help you in your failure analysis.
Punta ka dito.
http://tsikot.yehey.com/forums/showthread.php?t=10440Last edited by mark_t; December 10th, 2008 at 02:07 PM.
December 11th, 2008 08:42 AM #5
well, unang una, ung isang clamp for one of the radiator hoses was loose, kaya sumisingaw ung pressure. had to replace the clamp. secondly, meron napaka liit na crack on the radiator's top cover (disadvantage of plastic tops) kaya para cgurado pina tanso ko na ung buong ibabaw ng radiator. and lastly, ung relay para sa aux fan na nagpapa automatic sa kanya pag mainit was busted, hence ung fan intermittent na ang response nya. ok na siya ngayon, all in a days...errr...weekends work
December 11th, 2008 08:46 AM #6
December 11th, 2008 01:15 PM #8
Xiaomi E-Car
