Quote Originally Posted by Baltz View Post
Guys makiki-singit lang pero usapang kambyo.
1. What will happen if you are running at 4rth gear. Then went to press the brake. Speed drops at around 20kmph. Tas apak lang ulit sa gas?
2.what if you are running at around 45-50kmph, brake momentarily.
Shift to 3rd gear. Then car hesitates
Yung bang sobrang pigil nya tumakbo lahit anong tapak sa gas. Ano po kaya ng yare pag ganon?
Sent from my ASUS_X00DDA using Tapatalk
1. you can slow down but the revs will drop to a point the engine will stall. if this is an evasive emergency manueaver you won't have the engine brake to assist you and it will take a while to downshift. and if you stall you might lose brake pressure and steering assist. downshift if you need to slow down.
now accelerating from 20kph at 4th gear is called lugging. it's not good as explained by this guy
Why You Should Never Lug Your Engine (Especially Turbos) - YouTube
2. if the car hesitates then you're at a gear too high, downshift
. this is still lugging...
