Results 1 to 10 of 36
September 5th, 2007 04:27 PM #1
Tuto o ba na paminsan-minsan ay ihataw mo ang tsikot mo para daw iyong mga deposits sa makina ay matanggal?
September 5th, 2007 04:34 PM #2
Yes, but make sure you're not pushing it beyond its limit. That's overdoing it...
It's called an "Italian Tune Up". Go for a good long drive at high speed to make the oil hot and allow it to circulate in the engine really well and get the EGT's up there so that carbon build up in the exhaust manifold could be somehow burnt up (assuming it's not too thick yet). Otherwise you could have the manifolds cleaned if really dirty and then from there do the Italian tune up...
Most importantly be safe!
Zombie
- Aug 2006
- 728
September 5th, 2007 04:41 PM #3yep. there's truth to it. a few friends of mine in the states actually do it in a dyno since it's illegal to go over the speed limit.
September 5th, 2007 04:54 PM #6
Philippine roads cannot really vouch for this kind of long-distance, high speed driving (100+kph). I frequently go 80mph here in the US and sometimes it takes a few hours to get to my destination when going on long trips. That's when I make sure the oil level is just right, tires are good, cooling system checks out and I head for the highway once engine is warmed up.
It doesn't really matter how far, how long it takes, etc. as long as you get the car up to speed on a regular basis. It's just like exercise, you have to exercise once in a while to get that heart pumping. In the same manner you need to get that engine hot and running. This also allows the seals to get oiled and protected from getting dry, getting hard and eventually failing.
September 5th, 2007 05:36 PM #7
+1
although there are only a few public roads where you can do this safely locally (the stretch to tabang in NLEX is a good one, or the stretch past San Fernando although this is heavily monitored for speeders now).
The goal is to get the temperature up a bit, get that oil flowing and blow out those built up carbon deposits. But of course dont overdo it or you might end up damaging your engine even more.
Tsikot Member Rank 3
- Oct 2006
- 760
September 5th, 2007 10:17 PM #8Pag dinadala nyo sa mall on weekends, un medyo malau-lau sa inu at maluwang ang daan na hindi rin pahintu-hinto.
Sakin either SLEX goin to Alabang or STAR going to Lipa.
September 5th, 2007 10:43 PM #9
September 5th, 2007 11:15 PM #10
yan din ang sabi ng uncle kong mekaniko at ng tatay ko. paminsan-minsan ok lang ihataw, basta wag lang sosobra. sa NLEX 100-140 kph dun sa mga unrestricted zones kapag maluwag ang kalsada.
Air Mall or Assembly Grounds * The Rise.
Makati CBD parking
