Results 1 to 11 of 11
Threaded View
    Quote Originally Posted by badkuk
    a lot of cars i've seen seen to have a negative camber, at least on the rear wheels. makikita mo talaga that the wheels lean into the body. akala ko nung una, baka maluwag lang ang pagkakabit ng lug nuts; pero sobrang coincidence naman that both wheels are angled that way.
    Camber
    If you were to stand directly behind or in front of one of your tires to view its vertical angle, you would be looking at its camber. Actually, camber is most often set between 0 and -2 degrees, so you'd be hard pressed to see any lean at all. Negative camber refers to a wheel that is leaning inward with its top closer to the vehicle than its bottom. Positive camber, surprise-surprise, is the opposite, and means that a wheel leans out with its top further from the vehicle than its bottom. Many of the original Volkswagen Beetles had noticeable negative camber in the rear tires which made them look like they were squatting all of the time. A slight amount of negative camber setting is desirable because as a vehicle turns the outside wheels get pushed into a more positive camber state. This results in a camber of zero, or a straight up-and-down wheel, while cornering, which provides the largest contact patch and the greatest traction for handling.
    -edmunds tech center
    Ricers/Boy Racers exaggerate this for looks... the "trying hard to look like a racecar look".
    Too much camber will wear out the inner part of your tires.
    wheels rotate, so if the lug nuts are loose and the wheel is not bolted down to the hub, as the wheel rotates it will wiggle.
negative camber
