Results 1 to 2 of 2
- Dec 2006
- 1
December 1st, 2006 01:47 AM #1i have some trouble with my car, mazda, matic, regarding s rpm..stable naman sya pag naka idle, pero pagswitch mo n nang aircon nagflaflactuate ung rpm,bumababa sya from 10 to 0,hanggang s mamatay n ung engine. nangayayari din to paglipat m sa "Drive Mode" galing ng "Nuetral" . ive done the ff: pinalitan ko n lahat spark plugs, nilinis na serbo w/ carb cleaner,checked n air valve(serbo), fuel filter,new thermal switch,hoses..
sumasakit na kc ulo at bulsa ko kakahanap kung ano problema..
san po kya may diperensya???
cumputer box?
Distributor?
High tension wire?
hoping u could help me.... any suggestions??
December 1st, 2006 10:39 PM #2
Have you replaced said high tension wires? Spark crossfiring can be felt all across the rpm range, not just at idle...
The Computer box would also be my last suspect... are you sure you cleaned the throttle correctly?
Distributor? coil pack maybe? I don't have much experience with that particular model...
Xiaomi E-Car
