Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    pls help naman mga tsikot peeps. nagpalit na ako ng axle boot, bakit tumutunog pa rin pag lumiliko ako, lalo na pag todo yung liko? may dapat pa bang palitan? sabi ng mekaniko, ok pa naman daw yung tie rod, naka-align pa rin...ano problema??? :?:
    salamat po.
    lurker,
    did they check or repacked your CV joints? Or baka sa wheel bearings yan.
    Feb 2003
    alam mo ano yung tumutunog? "busted shock absorber". ganyan din nangyari sa car ko. nagpapalit ako ng cv joint may tok-tok-tok pa din ng sound pa lumiliko. after that pinatingin ko. shock absorber na nag. may singaw.... beware. paminsan kahit na sira na shocks mo wala itong sound pag nalubakan ka or whatsoever. basta bigla lang ndi papantay alignment mo.. after yung pinalitan na shocks ko. yun! nawala na tunog. and pantay na alignment!.....99.99% it might be your front shock absorber... replace them by pair.. try kayaba shocks. mas cheap pero maganda!:mrgreen: hope i can help
    Jan 2003
    replacing the cv boot won't solve ur problem pag yung cv joint mismo yung sira. either replace pag di na kaya i-repair.
    cv joint boot sabay palit na iyan sa cv joint more economical!
  6. FrankDrebin Guest
    Magkano na ba ngayon ang CV joint?
    Baka nde ung CV boot ung problem bka ung CV joint mismo...:roll:?? have it check n lng ulit jst 2 be sure....
    For sure Velocity Joint ang sira! Kahit i-repack yan, tutunog pa rin. Replace your CV joints asap :D
    Feb 2003
    Cv joint repacement "briggs" ang brand, replacement lang ito 3100 + labor pa, sa banawe............Cv joint boots mga 200 php..., anyways dalawa yung cv joint, may outer may inner, yung sa akin cv joint outer nasira..i spend almost 9k, on replacing the cv joint and shock absorbers(4400 php , pair), and labor, grabe naubos $$$$ ko, pero at least ok na dahil nawala permanently yung tok-tok-tok sound during turn.
    pinaayos ko agad dahil natatakot ako mamaya malubakan lang bigla matangal ang gulong!:mrgreen:
    thanks mga peeps for your help.
    if CV joint mismo ang defective na, malaking gastusan ito.... bakit kaya hindi naman napansin nung mechanic na may problema na yung CV joint eh binaklas na nga nila yun, nagpalit ng grasa at axle boot? pasensya na at wala akong masyadong alam sa mga parts ng kotse, yung CV joint ba yung may mga bearings? :oops:
    btw, sentra lec/ps ride ko. maraming salamat uli.
    Jan 2003
    hmmmmmm...baka naman fender liner lang or mags ang sumasayad pag lumiliko. ask the opinion of other shops.
    Feb 2003
    mmm, diba alam mo yung cv joint boot, yung cv joint ay nasa loob ng boot, it's like a long metal stick, hrap explain...
    pag may tok-tok-tok sound pag liko, probably punit na yung cv joint boot, pag walang punit, change the whole cvjoint outer set, pag may tunog pa din, shock absorber mo na yun, you just have to change it pair by pair , dahil malamang ndi lang isa problem ng suspension mo
    dagdag ko na lang....tie-rod,suspension arm and shocks will affect the alignment of the car, so kun nagdadrive ka and bgla ndi pumantay alignment ng car mo, isa na dito yung sira.
    pag ball joint, sa humps lang maririnig....
    tama ba ako ? hehe:mrgreen:
    Mar 2003
    sa tingin ko front wheel bearings yan...pa check mo... :D kse kaibigan ko same prob. din katulad mo wenever he turns may grumbling sound... pina check niya sabe ng mechanic front wheel bearings daw ang prob.. HTH :D
    again, tnx mga peeps....the best solution siguro is to go to another shop.....i'll try miller na lang....
    actually, labor ang mahal dito sa mga dapat pagawa na ito. eto ngang magpalit ako ng axle boot, 80 pesos lang each...mas mahal pa yung grasa! kaya sure ako na nare-pack yung joints & replaced na yung boot. if shocks naman, due for replacement sa siguro talaga.
    tnx uli...
  15. d3cipher Guest
    CV joint din ang guess ko....
    ung wheel bearings tumutunog all the time basta umaandar ang oto....
    parang umuugong.... parang eroplano tunog sa loob ng oto....
    have everything checked na din while you're at it, para alam mo na din kung ano pa ang dapat palitan in the future....
    hth! :D
    velocity joint yan, pareho bang tumutunog kahit kaliwa o kanan, ang alam ko pag lumiko ka sa kaliwa at tumunog kanan ang problema, correct me if wrong.
    left or right turning, tumutunog, both sides may naririning ako....basta todo liko lang, if not, hindi naman tumutunog...tok-tok-tok-tok ang tunog eh...
    tnx.
    Feb 2003
    ok lurker, tatlo lang sira nyan...
    1. wheel bearing
    2. C V Joint
    3. Shock Absorber...:mrgreen:
    Since we're talking about underchassis kalampag. Share ko na rin what i know that needs to be replaced kapag may kalampag/toktoktok/ugong sound na. Guys, feel free to add anything that i might have missed:
    1. Ball joint
    2. Tie rod
    3. Tie rod end
    4. CV Joint
    5. Wheel bearing
    6. Shocks
    Anything else?
  20. FrankDrebin Guest
    Bumping up!
    :D
nagpalit na ng axle boot/CV boot, may tumutunog pa rin!!!
