Results 1 to 18 of 18
    Jan 2008
    i got it dec 2007, di ko po alam last tune up nya. pag idle then nasa 800 rpm, possible pa rin po ba maging advanced masyado yung timing? kun ganun, hiramin ko timing light ng kapitbahay ko para ma check. i think there's a way para makita ung timing through one of the external pulleys.
    May 2007
    either you use a higher octane fuel or retard mo ng onti ang timing.
    or check overall tuning.
    Jan 2008
    ang kailangan po ba i-adjust kun sakali is ung distributor assembly?
    tune up muna...
    Bro, i've had the same problem, i had a MITSU GALANT 1999 and it would make a knocking sound kung irerev ko, parang may loose sa mga pistons or something sa loob. that might require overhauling the engine.pero ipapa check mo muna atleast 3 or 4 different car shops para malaman mo kung ano talaga.
    Jan 2008
    Quote Originally Posted by drew_5950 View Post
    thanks bro! fortunately 'pinging' lang or 'tope' yung naririnig ko and it only occurs sa third to fifth gear. nawala naman sya nung nagpalit ako ng replacement filter. although OEM yung nakalagay dati, luma na kaya siguro di maganda air flow.
    sir OT lang po, 4AFE po engine nyo diba? 2K RPM at 3rd gear 60KPH? huhu, d ko na alam gagawin ko sa corolla ko,, 60KPH is 2.5K RPM at 4th gear pa aken sabi nila gauge ko may problem, pero la naman ako makitang panel gauge na pampalit
katok sa makina
