Results 1 to 20 of 20
    Aug 2003
    pagkakaalam ko , that needs to have
    1. high ground clearance
    2. waterproof engine bay(um, i guess for really extreme cases na to)
    3. the air intake mounted up high
    4. exhaust mounted up high
    5. battery and connections waterproofed, or mounted up high
    just wondering that while some do have snorkels or have their air intake mounted high, few bother to do the same with the exhaust. ok lang ba na lublob sa baha ang tambutso, so long as walang papasok na tubig sa intake? di ba pwedeng pasukan din ng tubig at the other end(exhaust)?
    how high is the flood that you are talking of?
    I was able to ford floods of around 2 feet plus with our 323 without a problem.
    same with mazda2.
    went around 2 feet of flood too sa buendia (tapat ng Grepalife) with my singkit before...
    pero lam ko chamba na lang yun. hehehe.
    Jul 2005
    the problem of lublob ang tambutso while traversing flood is chance of choking the engine due water rush in that will cause dead engine and get stranded, so maintain ur revs high all the time if u think ur exhaust is submerge.
    Aug 2004
    Flood resistant? Except for SUVs and AUVs, the best cars I can think of are Mazda 323s, 626s and Ford Lynxes, with their high air filter intakes. Most new cars now have air filter intakes near the top of the engine bay, also. Most carburated cars have high intakes, due to the downdraft carbs and engine-top airfilters.
    Non-flood resistant, though, would have to be the older ECCS (up to 2000) Sentras (don't know about the intake on the new ones), as their airtube is headlight level and below, and the Optra, with its very low intake. The Mitsubishi Lancers with the INVECS is very vulnerable, as there is approximately 100,000 pesos worth of computer boxes to replace if the inside gets flooded (as opposed to 20-40,000 pesos worth on most other cars. Anyone know any others?
    Bottom line, If you're going to ford a flood and your car is EFI, if there's a danger of water seeping through the doors, forget it... save your electronics.
    Jun 2005
    The obvious winners in deep water fording would be the tall SUVs and AUVs. Not only are they tall enough to keep most of the water-sensitive components dry, most of them are already quite water-proof from being diesel-powered (with virtually waterproof mechanical injection).
    When it comes to cars, you're better off avoiding deep water altogether. Sure some cars might be able to take 2 feet of water, but that doesn't mean that the differentials and the transmission was spared from water ingestion. It might not develop any problems immediately, but if that water is not removed, it will definitely cause some corrosion inside amongst the drivetrain components. That's not even counting the dirt that get's ground in between the gear and bearing surfaces.
    Deep water-fording vehicles have large tires keeping the vital machinery away from the water level. In addition, they've also been modified so that the breather ports are connected via hoses into the safety of the high cabin.
    tama si shadetree, kasi nung nangyari to sa akin (see my previous post...) palit ako lahat ng differentials and joints dahil kinalawang yung loob.
    Aug 2003
    actually i thought about this while reading the APV brochure. i was saying to myself na ok nga ng ganyang kataas na intake, pero lublob pa rin ung exhaudt
    same with those large 4x4 pickups na me snorkel nga, pero no modifications sa exhaust( as compared to a Humvee).
    pero i guess if your electronics aren't really water tight, tirik din ang aabutin mo B)
    diba may thread na tayo about paglusong sa baha?
    Quote Originally Posted by badkuk
    ...same with those large 4x4 pickups na me snorkel nga, pero no modifications sa exhaust...
    That's because diesel engines have higher compression ratio which has more exhaust pressure out to keep the water from going in.
    IMO - kaya nga kung imomodify mo ng husto ang oto mo just to suit baha mode i would suggest na i-sell mo nalang car mo and get a pick-up or auv instead. the isuzu fuego is one of the best in suspensions (rides like a car) sa mga pick-up if you worry about riding comfort.
    Aug 2003
    er, no plans naman po to modify. nastuck kasi kami last monday sa baha, at pinag iisipan ko ung 'floodproofing' while waiting for the waters to recede
    Aug 2004
    hmm... I'd say, check your door seals and make sure the rubber is in good condition, find out where your computer box is... if it's on the floor, like in many passenger cars, learn how to disconnect it in the least time possible, or find a way to relocate it higher.
    I know some tuners train themselves to do this, as the computer box is the single most expensive part that will DEFINITELY be ruined in a flood.
    Feb 2005
    Flood resistant car? How about a flood-gliding car:
    Meet the Aquada, the aqua car
    This car is made by Gibbs technologies, a British car and tech firm. Their Aguada CAN DO 100mph on land and 30 knots in water. The engine is a 175-hp 2.5-liter V6 for a Land Rover.
    The bodywork is a water-tight composite construction of top and bottom halves- hull and upper deck- hung from a frame of alloy extrusions bonded and riveted together. The running gear starts more conventionally- a mid-mounted engine driving the rear wheels through an automatic five-speed Jatco gearbox. But then it gets interesting. The output drive employed by Land Rover to power a second axle is put to use driving a water jet with 2200 pounds of thrust. ven the cooling system is complex, with a conventional air-cooled water radiator for road use and a water-cooled heat exchanger for boat use. The suspension defies motoring convention, too. Basically it is wishbones front and rear, but to switch into water mode, the wheels fold up into the wheel arches. Switching from road to water takes just a few seconds as a pushbutton automatically activates marine lights, deploys trim tabs, switches to marine drive and folds the wheels. A bunch of sensors ensure that the folding action is never repeated on land.
    The price: $ 250,000.
    30knots. that's fast.
    Aug 2003
    would it be fair to say that the older(meaning carbureted, no computer box, etc) cars are more flood resistant than their electronics-laden brethren?
    Yes!
    carb patuyuin mo lang at changeoil takbo na agad hehe.
    Aug 2003
    deym...pumogi si ae92 ko ah :D
    mukhang walang problema yung lubog yung exhaust tip sa tubig... hindi mamamatay yung makina o papasok sa tambutso yung tubig kahit idling lang with the tip submerged.
elements of a flood resistant car
