Results 1 to 9 of 9
    What do you think?
    Dami auto ngayon na Single na lang ang fan, wala ng auxilliary.
    Parang delikado pag naluma. in my experience ilang beses na din akong nailigtas ng Auxlliary fan from overheat
    I thought the earth is geting warmer???
    Quote Originally Posted by MAXBUWAYA View Post
    I thought the earth is getting warmer???
    Yes, it is... but it's not getting smarter.
    Aug 2005
    no over heating problem with the 2001 ZZ. lalo na walang problem sa 2007 avanza.
    Although nagpalin na ako ng radiator fan motor sa ZZ kasi parang may gilingan na tunog. maybe the bearings.
    Apr 2011
    sir, balak ko ksi lagyan ng auxiliary fan un harap ng condenser ng avanza ko, ano kaya pwd dun?
    Quote Originally Posted by crispulostore View Post
    You can try check if the fan from the Kia Pride would fit. It's relatively thin so you can have enough clearance.
    *GH :
    2 ba ang fan ng EX & ASX ?
    *GH :
    yes... two fans.
    Most probably the engine of today being more efficient in design and the oils are better than before also, plus cost-efficiency pushing top manager to engr's to develop engine that require less parts makes for single fan cars capable of maintaning the optimal operating temperature.
    Smaller engines produce less heat. Hence less need for a lot of air flowing through the radiator.
Single fan design of todays car.
