Results 1 to 10 of 12
- Feb 2004
- 200
June 8th, 2004 02:01 PM #1hi,
which is better 1999 glxi or 2K glx? how would you compare them in terms of engine and performance?
many tnx,
June 8th, 2004 02:09 PM #2
i own a 2k glx. nothing special. carb engine, good for daily use. reasonable gas consumption.
i think that the 1999 glxi's engine displacement is bigger than the 2k glx (1.6 compared to 1.5). aside from the fuel injected mechanism, i think ala namang pagkakaiba yung other specs.
- Feb 2004
- 200
June 8th, 2004 08:34 PM #3oic, so carb pala ang glx. all power ba sya?
correct me if i am wrong, pinakahuling glxi ay 1999?
nu ng equivalent nito sa latest model ng lancer? mx ba?
June 8th, 2004 08:52 PM #4
Nung 2000 MX na ang highest model, may INVECSII sports mode, then may GLS, then GLX. GLX yata ang 1.5 carb.
June 8th, 2004 09:07 PM #5
yup carb siya butchokoy. weird nga kasi ung previous lancer (itlog) na 1.5 model(gli) ay fuel injected tapos ung next version ng 1.5 lancer (pizza pie - glx) carburated. in other words, downgraded. pero afaik, all power siya, power windows, door locks.
ang highest model ngayon ng lancer ay "mx" (evo7 body) ang next ay glxi tapos ang base ay "gls" wala ng el model.
- Feb 2004
- 200
- Feb 2004
- 200
June 14th, 2004 02:24 PM #7the reason why i ask this kc..
currently, my ride is glxi 93. ang balak ko sna modify at pagandahin kso naisip ko medyo luma na sya i was thinking to get a glx or gls na 2K then yun n lng ang modify ko? ok ba to? pero la pa akong money ngayn e, hehe!
btw, ok pa bang pagandahin yng current ride ko?
what do u think peeps?
June 14th, 2004 02:51 PM #9
May projector lamps ba ang itlog? Nagtanong ako sa Banawe ang sabi nila sa akin multi-reflector lenses or clear lens lang daw meron.
- Feb 2004
- 200
June 15th, 2004 07:30 PM #10nu ba ang advantage ng projector lamp, multi-reflector at clear lens. yng pong stock nu ba tawag dun, hehe!
sensya na sir newbie lng po..
high idle RPM at engine start
