Results 31 to 40 of 102
- Jun 2004
- 1,311
July 31st, 2005 10:19 AM #31So it would be safe to say that it actually works? What is it called? I'd like to read up on more information regarding this.
July 31st, 2005 11:19 AM #32
it works. the principle is based on giving the car body an electrolitic charge that repels oxygen, acids and salt.
you can achieve the same effect by soldering/bolting a piece of zinc bar to the chassis and car body panels. or simply getting a can of cold anodizing paint (zinc paint) and spraying the inside panels of the car body.
SiRaNeko
- Jan 2003
- 973
July 31st, 2005 08:32 PM #34
ang alam ko aluminum paint gamit nila, that is why pag nagalusan mag-rust din. zinc paint has anodizing effect, kahit na magalusan hindi mag-rust kasi zinc acts as the sacrificial metal.
July 31st, 2005 09:00 PM #35Originally Posted by yebo
saan ba available ang zinc paint at paano i apply ng maganda ba.. spraying or by by using a paint brush..TIA
- May 2004
- 903
August 16th, 2005 11:03 AM #36Sir saan nakakabili ng Zinc paint? Kasi yung Zinc bar sabi sa aken it works pag kumakalat yung Zinc sa metal portion.......
August 16th, 2005 11:13 AM #37
yung spray can Zinc-It ang brand name. di ko na remember saan ko nabili pero handyman yata
- May 2004
- 903
Tsikot Member Rank 3
- Oct 2003
- 734
August 16th, 2005 11:35 AM #39may number ba kyo nun electronic rustproofing alam ko sa quezon city lng yan. tagal na nyan ah. di lng ako makapagpalagay dhil wlang sobrang dtng.
pag ganitong tag ulan lam ko may promo sila...
may number kyo?
thnx
August 16th, 2005 01:58 PM #40
hello po
may binebenta sa akin na EP Electronic Automotive Rust Control for 1,000 pesos
it will prevent daw rust from forming and continue on the vehicle
may naka gamit na po ba nito? effective po ba? ano po reviews?
parang ganito po itsura nya...
dalawa po yung plates nya for SUVs
http://www.roemarketing.com.au/whatItLooksLike.html
more info here
http://www.ruststopnorthamerica.com/...protection.htm
installation instructions.
http://www.ruststopnorthamerica.com/...structions.htm
high idle RPM at engine start
