Results 1 to 10 of 16
- Nov 2002
- 5
January 16th, 2003 12:43 PM #1help naman please! paano po ba tamang diskarte kapag nagdadrive
sa mga downhill o pababang terrain? madalas kasi nangangamoy sunog yung brakes ko o di kaya halos ayaw na kumagat ng preno ko!
salamat :lol:
January 16th, 2003 12:49 PM #2
- Nov 2002
- 162
January 16th, 2003 12:53 PM #3kala ko uv been watching too much Initial D. :mrgreen:
pano ka ba magdrive? do u shift into neutral?
I guess depending on ur speed na din, pero normally don't rely too much on your brakes, "engine brake" ka. sample is 2nd gear ka then don't step on the gas, malilimit nito yung speed mo coz ur engine is doing some of the braking for you. No gas, no acceleration.
January 16th, 2003 01:13 PM #4
madalas magfade ang brake like going to highlands tapos mabagal ang gapang pababa...
one thing you can do to improve the situation is to use a better brake fluid... some brakefluids boil too easily eh... i don't know what brand is good, but may difference yan for sure...
another thing is to make sure that your brake system is well bled, meaning walang air bubbles sa brake system mo, kung meron, mas mabilis talaga magfade ang brake...
third.... tips nila using engine braking... so try not to gas up na when going downhill, the slower your momentum, the less effort you need to stop the car.
January 16th, 2003 01:38 PM #5
stay in gear lang. the appropriate gear is dictated by the speed that you are driving. avoid using your breaks alone.
- 94
January 16th, 2003 07:40 PM #6sabi nila, kung anong gear ginamit mo paakyat, yun din ang gamitin mo pababa on the same route ( pabalik ) ....... then tulungan mo na lang ng occasional touch sa brake pag tumataas yung RPM mo habang pababa ka......
so far effective sa akin yun .......
January 16th, 2003 09:33 PM #9
tanong lang po, kapag nag-eengine break ka ba, gumagamit to ng fuel? kasi tumataas pa rin yung needle ng tach pag ganon eh..
January 16th, 2003 09:45 PM #10
tataas talaga yung rpm mo above idling kasi the speed of the drive wheels (which tends to increase going downhill because gravity is making your car go faster) is influencing your engine rpm, how much depends on your car's gearing... your fuel consumption won't be any different at 1500 rpm engine braking and 1500 rpm cruising
let me understand... when you first start the cold engine, the rpm is 1800, then when the engine...
LANCER Itlog (93-96) Owners - Please Post Here!
