How do CVTs work. Is it true that belt lang talaga nag papaikot ng mga pulleys? How is this in terms of reliability?
New City and New Lancer owners with CVTs. I would greatly appreciate your feedback.
Thanks!
Thanks!
sir paki check itong site na ito:
http://cvt.com.sapo.pt/toc_en.htm
i hope it could answer some of your questions.
CVT stands for Continuously Variable Transmission, which is an automatic transmission that has an infinite number of ratios between bottom and top gear. The control system automatically selects the most appropriate ratio and thus engine speed, so that engine power is applied to the road wheels in the most effective way in accordance with the driver's wishes and the prevailing gradient. The action is totally smooth, without bumps or jerks.
sa madaling salita, its smoother than the conventional A/T dahil nga sa infinite gears to pick from when accelerating and or decelerating. Dahil din po dito, mas magtatagal ang buhay ng A/T.
Taliwas sa 4-speed A/T and M/T na may katapusan ang gears. Mas maiintindihan ang gearing kung malalaman mo kung paano gumagana ang transmission.
Uy! nabuhay si Karding!!! musta na!Originally posted by Karding
Signature
Fenderbender yung Belt ng CVT ay as reliable din ata ng Chain or timing belt sa engine >>
Imagine pag nasira Timing belt ! >>
Yung scooter ba e CVT rin>>
if you are going to turbo a car... why get a CVT based tranny car in the first place?
Anyway, a CVT will handle a maximum amount of power... beyond that, the CVT's bands will slip and loose power, eventually break.
adding more power to a fuel efficient transmission i guess...although combining turbo with fuel efficiency seems like a paradox
anyway, found the answer myself.. a cvt can handle turbos - i.e. audi's a4 1.8T has a cvt option
a CVT will handle a turbo if the turbo came as a factory option.
BUT if you plan to upgrade your lancer CVT with a turbo, you might want to do a bit more research to see how much more power YOUR cvt will handle without breaking.
My Mini has CVT with Paddle Shifter...regular drive mode is a little slow to pick up when you need the power as it somehow forces a glide...on sports mode, its a totally different story...it red lines before upshift so you max each gear level and get max torque. Totally exciting.
I know you can supercharge a Mini CVT as it an option from JCW, which a BMW certified tuner for Minis.
