Results 1 to 18 of 18
    Aug 2019
    Good day po.. i just want to ask, my honda civic 1997 just suddenly increases rpm when ever i step on the gas... i tried to observe when i happens, and i noticed that when ever i reach 30 ro 40 kph may rpm just suddenly shoots... para tuloy nirerevolution un kotse bigla.. i release the gas pedal and it stops.. ano kaya nangyari? Thanks in advance.
    Apr 2019
    Quote Originally Posted by Nyaminya View Post
    VTEC? Driving habit or driving style? A/T or M/T?
    my honda civic 1997 just suddenly increases rpm when ever i step on the gas... .
    Isn't this normal...Lol
    [emoji2962]
    May license ka ba?
    Aug 2019
    Sa mga sumagot sa akin question, it seems ang gagaling na ninyo magdrive. Yes I have had a drivers license since 1997 i have been driving manual and automatic, in the philippines and in north america. My car is a honda civic 1997 AT Vti. I dont think it is driving style... normal ba na tataas un rpm kapag magaccelerate na di na aakyat ang speedometer pero un rpm tumataas pa din? Na parang nakastand still un sasakyan pero parang nakaneutral habang nagrerevolution un engine? I dont think normal yun and i have driven enough years naman na siguro to know if it is normal or not.
    Magkaiba kasi ang original post mo at ang reply mo ngayon.
    Malaki ang pagkukulang sa original post mo kaya normal ang reply sa iyo.
    Ngayon mo lang sinabi na umaakyat ang rpm pero hindi tumataas ang speed. Ika nga, wording malaki pagkukulang.
    Sa sinabi mo, hindi ko sure kung anu issue diyan pero baka, baka transmission related na nawawala yung higher gears na at hindi makapag shift up.
    Ang nearest experience ko lang is 2003 xtrail ng kuya ko, hanggang 60kph lang takbo at 2500 to 3k rpm na kami wala na talaga ibubuga yung kotse. Overdrive on or off, same situation, so naging suspect, nawawala na yung 4th gear sa shifting option ng kotse.
    Jan 2009
    Based on those symptoms, my best guess is that that the clutch is slipping.
    If it's still using the original clutch packs from 20+ years ago, it's definitely time to replace them. Otherwise, it may just need certain adjustments or an ATF change.
    MT? the clutch (disk) is probably worn and needs replacing.
    AT? atf only, if you are lucky. AT needs to be opened, if you are not that lucky.
    i recently had my altis's AT fixed. the stick wouldn't rake nicely. first time i heard of "AT overhaul kit". it costs a pretty bundle.
    Jan 2008
    Sunget mo naman... kulang kulang kasi info mo kaya ganyan sagot..
    Kung AT yan.. clutch slipping ang tawag dyan.. malamang between 2nd gear to 3rd gear yung slip na nararamdaman mo based sa speed mo na 30 to 40 kph..
    Check your atf level, color and smell.. check level while engine is idling. cycle the shift stick to all gears. When the rad fan kicks.. check atf level between Hot zone.
    Using tissue paper (white) check its color.. should be reddish in color. Then sniff the atf for any burnt oil smell
    Aug 2019
    Thank you sa replies. Maybe di ko naclear un pagsabi na pag mag 30 kph na speedometer mag shoot up un rev ko.. may kakulangan man, di naman siguro appropriate na isagot eh may lisensya ba ako..... anyways salamat sa pagsagot will bring it sa mekaniko today and hopefully, i will get lucky. Have a good day everyone.
    Aug 2019
    Hahaha sunget ba? I dont think I can be funny enough when i think na baka may mangyari sa akin at sa kotse while driving pag nagkaganoon nga un pag rev bigla ng sasakyan. I will try to be more clear next time to avoid any misunderstanding
    Jan 2008
    Try mo muna flush atf then replace atf filter.. search mo lang car model mo kung may atf filter..
    MAKE SURE TO USE THE SPECIFIED AT FLUID!!
    wag maniniwala sa mekaniko na pwede yung universal atf
    yup.
    civic ini. even if 20 years old.
    get it from the honda casa.
    may history na ang honda vis a vis transmission fluids.
    'buti na yung sigurista. that way, we will be removing one possible, even if unlikely, variable, from the equation.
    Hopefully makuha sa atf change. Sa xtrail namin, hindi nakuha. For city driving naman lang ginagamit so since hanggang 60kph naman yung 3rd gear niya, medyo usable naman and walang real world issue
    Aug 2019
    Thank you for the replies. Now , any suggestions where is the better if not the best place to have an ATF flush.
    Kahit saan talyer or gasoline stations if you're just gonna do drain and fill.
    You could try Exalta. N. Roxas St., Banawe area. Ask them how much atf you'll need.
Civic suddenly revs
