What do you folks think?
* 6-piston front and 4-piston rear calipers
* Cross-drilled rotors
* Aluminum engine block with 104.8-mm bores and pressed-in liners
* Forged steel crankshaft with 101.6-mm stroke
* 6-bolt, forged steel main bearing caps
* Titanium connecting rods
* Cast aluminum flat-top pistons
* Racing-derived CNC-ported aluminum cylinder heads with 70-cc chambers
* 56mm titanium intake valves
* 41mm sodium-filled exhaust valves
* 11.0:1 compression ratio
* Composite manifold with 90 mm single-bore throttle body
* Camshaft with 15-mm (.591-inch) lift
* Dry-sump oiling system
* 7000-rpm redline
WEIGHT: 3130lbs/1420kg
500hp/475lb-ft torque.
... so beautiful.
