help! my high beam does not work. My low beam works but once you switch it to high beam, total darkness.
I can use the flash when the headlights are turned off though so I'm thinking the bulbs are still good.
ano problema nito? wiring? fuse? relay?
i haven't open up the hood yet kasi late na.
suggestions naman para ill know what im looking for na tomorrow.
guys, balitaan ko lang kayo. naayos ko na. busted fuse nga.
at first tiningnan ko yung mga relay, ang weird from high beam naging low beam naman yung hindi gumagana nung kinalas ko and kinabit ko uli. :roll:
then chineck yung fuse that come from the wires from the + side of the battery. checked using a multi-tester for connectivity, dead yung isang fuse. Wala akong mahanap na 25A na fuse so kinabit ko muna yung 30A. Bukas ko na uli palitan. D ko naman na gagamitin, for emergency purposes lang.
