Results 1 to 10 of 10
- Jul 2008
- 176
March 22nd, 2009 11:34 AM #1sorry, tried searching but i could not seem to get the answers i need.
anyway, what basic tools do i need to have in the trunk of my car? at home? i know may tool set na kasama yung auto pero tama na ba yun? i'd like to be able to bring tools that a mechanic would need in case the car breaks down for some reason.
also, i would have wanted to get wrenches (socket/open ended) pero what sizes are most useful/used? sayang naman ang set kung hindi naman magagamit lahat.
thanks in advance!
- Jul 2008
- 176
March 22nd, 2009 12:21 PM #4
Socket and wrenches (box and open) FROM 8MM to 14MM, pair of pliers (long and short), wire cutter, one adjustable wrench and screw driver (flat and hex).
Like this craftsman tools.
March 22nd, 2009 12:26 PM #5
eto ang importante, sizes 10, 12, 14, 17, mapa open, socket, o box wrench.
a set of screwdrivers, small ones and big ones, philips at flat.
jack, kung kasya, alligator jack ka na, kahit 2 tons lang
spark plug wrench
cutter o blade
yan lang ang naiisip ko. syempre wag kalimutan ang tyre rings
March 22nd, 2009 01:38 PM #6
thrown in a roll of duct tape or similar high strength tape like strapping tape. You never know when you need to tape up something.
Jumper cables and tow cable as well.
Early warning devices like those reflective triangles or a couple (collapsible) road cones.
- Mar 2009
- 72
May 6th, 2009 10:04 AM #7Aside from the suggestion
1. Electric tape
2. Basic fuse for you car
3. bulbs for your car
Check out the basic sizes you use for your vehicle.
Learned in my advie na need ko ng size 22 in order to remove the spare tire.
May 6th, 2009 11:20 AM #9
a pair of gloves, para hinde sumakit yun kamay in case kailagan meron kang gawin kahit na mag change tires masakit sa kamay...
flashlight pa pala
May 6th, 2009 12:11 PM #10
eto similar thread 2 years ago... mods pa merge na lang.
http://tsikot.yehey.com/forums/showt...ic+tools+trunk
