Results 1 to 14 of 14
    Feb 2006
    had the breaks checked and new master last year, new battery last year, engine oil 2 months ago, new radiator.
    Whats next?
    ilang kms odo? anong car?
    afaik, ito yung mga kailangan palitan:
    1. timing belt
    2. tensioner bearing
    3. crankshaft oil seal
    4. camshaft oil seal
    5. silicon gasket
    6. auto tensioner
    7. water pump (if necessary para isang gastusan na ng labor)
    cmiiw.
    how about your clutch system, is it still okay? no problems shifting?
    Feb 2006
    Clutch is ok, may cranking noise lang ang gear sa reverse, sa forward gears, smooth sya.
    got this checked, fixed maintained, listed are the ff.:
    1. Timing belt, 95,000 Km
    2. clutch secondary repair kit
    3. B/N evercool radiator
    4. engine oil, 2 months old, less than 2,000 Km
    5. Battery, 4 months old
    6. brake master, 1 year old
    7. brake pads, 4,000Km
    Oct 2005
    Quote Originally Posted by mr._bator
    sir kayo yung may EG hatch no? ...hmmm... i might as well follow this checklist. thanks...any ideas kung magkakano ang belt tensioner? at mga seals?
    well you've covered almost everything, I guess you just have to wait for the normal change-oil/tune-up interval.
    Kung gusto mo naman ipa paint wash-over mo na
    Apr 2005
    depende sa condition ng individual components, normally if the car is more than 5 years old:
    check (and replace if necessary):
    1. suspension bushings
    2. dampers
    3. tie rods/end
    4. boots and grease (axle, r&p)
    5. gear oil
    6. fan belts (a/c, alt, p/s)
    7. undercoating/rustproofing
    8. tires, wheels
    . . . and more.
    Aug 2004
    change fluids: power steering, transmission, clutch, brake fluid, etc.
    Feb 2006
    Had it painted already last sept 2005, stripped to metal.
    bushings and suspension were also covered last sept 2005.
    maybe, the transmission fluid will be my next plan, ipon muna ako.
    pawis steering naman kaya wala ako steering fluid. hehehe.
    tires ok pa ang thread, makapal pa, less than 2 years pa lang kasi.
    umzzzzzzzz: if magpapalit ka na ng timing belt, might as well change water pump na rin. Kay speedyfix, mura lang, less than php 7.5T gastos ko. parts and labor. in 3 hours natapos. malilibang ka pa sa 29" cable tv sa waiting area, or sa mga FHM saka pump mags, hehehe! Kung car mags naman meron din.
    1. timing belt
    2. tension bearing
    3. water pump.
    4. crank and cam shaft oil seal
    5. ditributor O-ring
    6. valve cover gasket
    7. labor
  11. rey_rya Guest
    may I suggest checking your wheel bearings..repack or replace then check grease points of balljoints-maybe it needs greasing..happy driving!
    Dami nyo na napagawa Mr. Bator a! Kainggit naman!
    Ako eto still in the middle of preventive maintenenance. Kakabasa sa mga forums kung ano ano nalalaman ayan tuloy hehe.
    Hayyy... kung may unlimited supply lang ng moola e hehe.
  13. #13
    mr.bator: what's your car?
    Feb 2006
    garyq : Civic 94 hatchback, stock engine
    typhoon : yup, dami ko nga napagawa, ubos naman ang savings!!!! hehehe!!!!kaya sobra tipid ako ngayon. di tuloy makapagpa-full tank.
Afte timing belt, whats next for preventive maintenence?
