Results 1 to 10 of 18
- Aug 2005
- 118
- Aug 2005
- 118
October 18th, 2005 08:33 AM #3Originally Posted by theveed
October 18th, 2005 09:14 AM #4
mga sirs panu naman kung mag-papalis ng acid etch na un? nakabili kasi ng rear windshield dad ko na may naka-etch pang plate #....uyy, di carnap ung pinagbilhan nyan...
- Aug 2005
- 118
October 18th, 2005 10:49 AM #5Originally Posted by alwayz_yummy
October 18th, 2005 02:17 PM #7
anti-etch? hehe lagyan mo nalang ng sticky sticker hehe :-D
which is better? Laser etch o acid etch?
October 18th, 2005 04:05 PM #8
same lang ang laser etched with acid etched both can't be erased or reversed. but the thing with laser etching is that since the laser is in a machine you will have to remove the part you have to etch so we can laser etch it for you.
another process is sand blasting which blasts micro emery powder onto the surface, like acid etching, this process uses stencils. also canot be erased. different process has advantages on certain materials and applications. we only do laser and acid etchings...
October 18th, 2005 06:11 PM #9
so, ang solution nalang is lagyan ko ng very sticky black tape para matakpan lang ung laser etched...
hirap kasing body parts nitong maxima!
thanx din...e kung papatungan ko ung etched na plate# ng solid na rectangle para mapatungan lang un....
October 18th, 2005 06:22 PM #10
pag etch no way to revert it back, etching may be done on almost all glass surface, ceramic n porcelain, pede din sa ipin
high idle RPM at engine start
