Results 1 to 17 of 17
    Aug 2015
    Pls help. Its my first time na mag PMS na 80k kms. I have altis 07 AT, ung iba sabi change lahat ng fluids aside from usual change oil at tuneup. Is that necessary? Balak ko din palitan na serpentine belt.
    Thanks!
    Jul 2010
    Yes sir that is correct. It is required to change all fluids on your car.
    Jul 2010
    Quote Originally Posted by unmarked View Post
    Thanks!
    fluids change has a schedule. consult the manual po. if you do not have one, consult the casa.
    complete change of fluids in a newly purchased used car, is more for surety and peace of mind... just in case previous owner "manhandled" the car.
    same with that serpentine belt..
    belts have telltale signs of "time to replace".. look closely at them. if they have tiny linear cracks, even one only, replace. if you want peace of mind, replace.
    40k and 80k 120k are the same. Complete all fluid change.
    Aug 2004
    yes, change all the fluids.
    it's also good to change the serpentine belt.
    i also have a '07 1.6e altis mt and changed the belt during 60k and 120k preventive maintenance.
    Aug 2015
    Thanks sa lahat ng responses nyo. Malaki laking gastos ito. How about fuel filter? If it hasnt been changed, kelangan na din ba for peace of mind? Ala atang visual inspection to? Tama ba?
    Aug 2004
    change fuel filter every 40k.
    Aug 2015
    Quote Originally Posted by mcbry View Post
    thank you sir.
    kung ayaw ko sa CASA, san maganda/recommended to? gusto ko sana one stop shop. meron bang kaya yan lahat? pati piyesa kanila na galing? kung may alam kayo within Metro MNL pa suggest naman.
    -all fluids (engine, atf, brake, radiator, power steering)
    -all filters (oil, fuel, air)
    -brake pads
    -serpentine belt
    thank you sir.
    -brake pads
    -serpentine belt
    Jun 2005
    thank you sir.
    -brake pads
    -serpentine belt
    thank you sir.
    -brake pads
    -serpentine belt
    gas station kayang kaya yan.
    or servitek
    Mar 2015
    thank you sir.
    -brake pads
    -serpentine belt
    thank you sir.
    -brake pads
    -serpentine belt
    Baka gusto nyo sa cubao sa shop sa may p.tuazon or sa house nyo sir?
    Have a friend mechanic who does house calls. Just schedule with him if you like po.
    thank you sir.
    -brake pads
    -serpentine belt
    thank you sir.
    -brake pads
    -serpentine belt
    Powertorq on facebook have prices posted.
    Or Servitek shops.
    Aug 2015
    Quote Originally Posted by sirkosero View Post
    or servitek
    Ah ganon ba? Madalas ako pa change oil sa shell diko naisip na meron sila supply nyan lahat na available lagi. Sige check ko servitek. Salamats!
    Di karamihan nag papa pms sa mga gas stations. Even though madali lng fluid change. Some idiot mechanics might use wrong atf fluids and wrong engine oils like 15w50(too thick).
    Know what your car requires by reading the owners manual.
    Aug 2015
    Yeah true, pero most papapiliin ka naman ng gusto mong oil.
    Ball park figure kaya mga sir for all fluids and filter? Excluding plugs 6 mos palang e. Abot ba 10k?
    Aug 2015
    Quote Originally Posted by SkyFlakes88 View Post
    Malabo sir, wla akong garage sa apartment. Cant do it sa parents house.
    Thank you
    Mar 2015
    Thank you
    Ok sir may shop din naman kung gusto nyo. Malapit sa Lto p.tuazon. Whichever works for you po. [emoji4]
80k preventive maintenance
