This car belongs to Wesley Gatchalian. All conversion is done with guage #16 BI sheets.
He opted for a 289 engine with slight tweeking. The car has front disc and rack and pinion steering. Wheels are 18".
Actually yong un kong ginawa ang gamit ko cardboard lang. just to get the proportion.
Meron ding putty, pero not thick. Every weld mus have putty.
The main advantage of the metal conversion is that connections will not show hairline cracks after sometime. Fiberglass to metal will eventually crack after some exposure to heat and cold. And will also exhibit hairline cracks in the gel finish.
The metal, if properly prepared will last a life time.
Since the metal is formed and welded into place. It will take a lot longer to complete that a kit. But kits even coming from the US has some "fitting problems".
Fiberglass hood and trunks usually have fitting problems and stress cracks after some "open-close" cycle.
It takes a lot of super-precise skill to make those tires not rub against the wheel well like that. Wheel travel is tricky to just estimate. I guess you also did underbody strengthening.
It still has a 302(not a 289 that I previously mentioned).
I cut the old fender(using reciprocating saw) then had six oversized men(hehe) jump up and down in the trunk to simulate suspension travel. When proper clearance was achieved, I welded the fender flares to the fender. Now it won't rub.
My personal Eleanor is a lot more radical, though it will take some more time to finish. hehehe.
