Results 1 to 3 of 3
- Apr 2011
- 2
April 18th, 2011 09:41 PM #1mga boss, hingi sana ako ng tulong. medyo bago kase ako sa pagmod ng kotse.
hopefully next year, magkakakotse na ako - 2nd hand na 95/96 corolla with stock 2E engine. gusto ko sana mag-engine swap. palitan ko ng 4A-GE 16V. Kung may 4A-GE 20V, mas ok.
1. anong 4A-GE maganda ipalit? ano ba pinagkaiba usually nung Hi-Horse, Silvertop at Blacktop?
2. ano pa ung mga dapat palitan pag nag-engine swap?
salamat mga boss!
- Apr 2011
- 2
- Jul 2009
- 2,618
June 27th, 2011 08:23 AM #3Actually kahit Hi-horse (140hp), blacktop(170hp) or silvertop(165hp) would be fine.
Magaan ang kotse mo kaya any of the three put into your engine bay would be an improvement. Budget lang talaga ang major factor mo. Word of warning though. lahat ng 4age ay high revving kaya don't expect much oomph down low in the rev range kailanagan galitin mo talaga ang makina kung gusto mo ma-feel ang arangkada. This is especially the case with the black and silver tops.
Pwede ka din mag hybrid na combo blacktop tapos silvertop na ECU. That will work nicely.
Syempre pagbili mo ng makina dapat may compression and leakdown test for all cylinders baka may tama and you will really have to replace all fluids, sparkplugs pati plug wires siguro just to make sure. Also dahil may milyahe na ang mga engine na ito pag nakarating na dito satin sa Pinas best to replace the timing belt as well.
From what I have seen, some premium/performance makes, like BMW, suggest weights(sand bags) on...
Wheel Alignment
