Results 1 to 10 of 18
- Mar 2004
- 32
August 16th, 2006 04:49 PM #1maybe a stupid question pero ask ko lang kung paano pina-iispin yong back wheels ng car (rear wheel drive cars) na di ito umaalis hanggang sa umusok yong tyres?
August 16th, 2006 04:58 PM #2
Step and hold the clutch, put into first gear, step on the gas a little harder than usual then release the clutch but not in one jerk or you'll stall your vehicle.
However, I don't advise on performing this stunt/trick because it would do more harm overall to your car than good - gawd be damed the "pogi points" for performing this stunt/trick.
- Mar 2004
- 32
August 16th, 2006 05:25 PM #3
August 16th, 2006 05:29 PM #4
August 16th, 2006 05:34 PM #6
Make sure you ease on the clutch while pressing down on the gas pedal. I think it's bad for the timing belt. But, if the cloud of vaporized rubber is worth it to you, by all means try it. Just make sure you can afford new tires and expect to replace the timing belt much earlier than recommended.
Also like artpogi said, the clutch and/or gears too.Last edited by Jun aka Pekto; August 16th, 2006 at 05:36 PM.
August 16th, 2006 06:29 PM #7
kung auto, turn off esp or traction control kung meron then step on the brake then full throttle.
- Aug 2006
- 152
August 16th, 2006 06:40 PM #8Sa tingin ko front disc brakes lang yung naka equipt nun sa front at wala sa back. Kasi diba sa front wheel drive just pull on hard the parking brake then step on the gas, it will spin na. IMHO!
- Aug 2006
- 337
August 16th, 2006 11:33 PM #9manual: rev to 4000 drop the clutch step on brake with left foot, or heel toe it.
matic: right foot on brake and full throttle.
Be safe.Do it on open space.
- Aug 2006
- 337
August 17th, 2006 02:29 AM #10
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
