Results 1 to 12 of 12
    Jan 2004
    What are the benefits having these high tension wires installed? pros and cons? do i need to change spark plugs as well? any suggested/tested brands? thanks in advance
    may plus HP din un
    Aug 2003
    May plus fuel consumption din po ba? :D
    Jan 2004
    actually, high tension wires matched with iridium plugs(or splitfire) can give outstanding results. i suppose there would be some boost but not that great. i haven't tested it personally yet. theoretically, high tension wire suppose to have higher resistance in higher voltage, thus burning the fuel more efficiently. but be advised that high tension wires matched with stock plugs is doesn't really help. it is much better to retain the stock tension wires if you're going to use stock plugs.
    kindly correct me if i'm wrong...
    Jul 2003
    [i] but be advised that high tension wires matched with stock plugs is doesn't really help. it is much better to retain the stock tension wires if you're going to use stock plugs.
    kindly correct me if i'm wrong... [/B]
    IMHO, if you use HT wire with stock plug is much better(dunno the technical word) this is the advise given to me of one of the sales rep of BLU thunder HT. they showed me actual demostration if using BOSCH against OE sprak plug. result indeed encourage to maintain OE plug for my Blu thunder HT.
    kinda confused here. paki correct din po!
    peace!
    Please advise naman how much ang magandang HT sa Civic Lxi pwede kaya sa sa boasch platinum?
    Thnks.
    question po? pano po nailagay nung frontier ung high tension wire? e diesel makina nun?
    paki answer naman question ko...
    alam ko mas efficient yung pagdaan ng kuryente...plus hp? imo, very very minimal. if not none.
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Apr 2004
    pero pano sa mga kotse na distributor less? mostly ng lumalabas na kotse ngayon ay may coil pack na sa taas ng 2 spark plugs (directly connected) tapos may 2 wires lang leading to the 2 other spark plugs (in a 4 cylinder engine).
    ano naman kya ang benifits ng high-tension wires sa mga kotseng ganito? di ba asthetics lang kce multi colored wires lang mga to? hehe. no offense pero di ko talaga makita yung wisdom behind it. sa pagkakaalam ko kce yung current travels at a constant speed given na negligible naman ata yung difference ng resistance ng stock na wires compared to a high tension wire. correct me if i'm wrong pero wouldn't it be better to change the spark plugs nalang w/o having to change the wires?
    Dec 2003
    Hey guys ok ba ang blue thunder na high tension wire?
    2,500 kase bili ko since small lang yung car ko...Thanks.
    I agree with this yan din ang sinabi sa akin nung shop dito sa motortown sa amin..mas magiging maganda lang ang daloy ng kuryente niya..:D
    Based on experience, its better to keep the stock wires (make sure they're in good shape though) and plug set-up (properly gapped with the proper heat range specs). A friend told me before that the dynos at Autoplus could not pick-up any HP gains with such upgrades on basically stock/slightly modded engines (it can be diff if you're carrying serious mods and complete ignition systems though). You'll be able to free more HP by advancing the timing and using high octane fuel together IMO.
    Nov 2003
    don't waste money on HT wires. unless you have a heavily modified ride (turbo or high compression) you will feel minimal gain with the addition of the wires.
hig tension wires... what's with these?
