Results 11 to 20 of 166
March 31st, 2012 11:02 AM #11
WOW! kung ang price talaga nito eh between 900000 to 1000000 pesos (4x4) ... then this is worth a second look.
Kasi sa size lang... parang kasing size na nun bagong Ford Ranger...
Based sa specs sa papers... OK din engine, tranny, etc...
Sana nga totoo.
March 31st, 2012 11:06 AM #12
March 31st, 2012 11:18 AM #13
- Jun 2008
- 1,741
- 172
March 31st, 2012 12:26 PM #15110 kW (148 hp) at 3600 rpm, with peak torque of 360 Nm (266 lb ft) at 1800 rpm. Life to overhaul is expected to be 500,000 km. (quoted from SinoDiesel.com)
impressive numbers indeed. i can personally vouch for the reliability and durability of the cummins, but still has reservations on the ladder chasis and the front suspension.
- Jun 2010
- 452
March 31st, 2012 02:39 PM #16Looking at the pics, mukhang Hi-Lux based nga itong pick-up ng Foton. Side and rear pics remind me of the Hi-Lux.
- Jun 2008
- 1,741
March 31st, 2012 04:30 PM #17according to the bronchure and global foton website this cummins ISF2.8L CRDi engine is rated at 120kW.Front suspension is double wishbone and leaf spring in the rear. I visually check the ladder frame (including the welds) a.nd it looks ok to me, not much different from that of toyota & mistsubishi
- 172
March 31st, 2012 05:04 PM #18[QUOTE=weisshorn;1901400]according to the bronchure and global foton website this cummins ISF2.8L CRDi engine is rated at 120kW.Front suspension is double wishbone and leaf spring in the rear. I visually check the ladder frame (including the welds) a.nd it looks ok to me, not much different from that of toyota & mistsubishi[/QUOTE
then its sticker price is a steal. the cummins engine is quite reputable for truckers, since its a newly developed engine i hope the lineage of its big brothers (million milers) runs thru its veins errr oil galleys. 500,000 kms before an overhaul is impressive, if it really is, the body would have corroded into bits and pieces before the engine has to be pulled down.
btw my last engine pull down was a TD25 at 240,000 kms.
- Jun 2008
- 1,741
April 1st, 2012 09:49 AM #19Here are some additonal info from FOTON Global Site: Tunland L | Foton Global Website
Info regarding cummins engine:Cummins Engines - On-Highway - Light Commercial Vehicle - ISF2.8
PS. I'm not a salesman.
I'm just interested in this pick-up truck inspired by its 878K php price tag of the 4x2 manual variant.Last edited by weisshorn; April 1st, 2012 at 09:52 AM.
- 172
April 1st, 2012 10:25 AM #20i felt the clutch pedal is a bit to hard for me to depress and i did not see a transfer case shift lever on the 4x4 model. and there aren't any foton models to be found
so i went looking under the hoods of my city hatch and jimny. other than the plastic upper/lower of...
BYD Philippines
