Originally Posted by
essedes21
Hello po mga Sirs.... Can I ask help po regarding my ford lynx 2000.. Recently po, while i was driving, naramdaman kong parang wala ng hatak ung auto ko tapos nagvibrate ung makina...nag-pull over ako then ni-rev ko xa...tapos parang nalulunod...then kahit naka-neutral ako, pag-in-on ko ung aircon and lights..namamatay xa...may malapit na shell so dinala ko xa dun...chineck nila ung spark plugs ok pa naman..tapos nung kinabit ulit..ok na ung auto ko...high tension wire daw...nung umuwi ako, i asked a neighbor mechanic to check on my auto...di daw high tension wire kasi ok naman nung binunot nya..spark plug daw kasi palyado na daw ung isa..so what i did was to change it..ang suggestion nya is to use bosch platinum-iridium..ang dati kong gamit is bosch super 4...after ko magpalit ok nag-ok naman auto ko..den after a day nagganun na naman..nag drop ung rpm tapos ang vibrate ng makina na parang nalulunod, nung binalik ko sa mekaniko..coolant sensor daw...kailangan na daw palitan..mejo in-doubt na ako mga sir...ano kaya prob ng auto ko..any suggestion where i can bring my car para maayos xa..(wag lang po sa casa) thanks so much po...hope you could help me...
